View unanswered posts | View active topics It is currently June 19th, 2026, 10:53 am
Reply to topic  [ 429 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 43  Next
 BMW 2cv engine conversion "2.0"
Post Re: BMW 2cv engine conversion
ChrisW wrote:
Oh yes - by the way Geo - you called me a traitor for liking the green Bamboo BMW and now you are going to do it.... :twisted: :twisted: :twisted: :twisted: :twisted:
Only joking :D :D
Well I was joking too..... and I don't know if I'm going to do it yet, I'm just absorbing information at the moment........ With a new turbo I'm done, with a Beamer engine it just starts (money- and timewise........)......
to be continued......
September 19th, 2013, 9:17 pm
lpgo wrote:
Only joking :D :D
Hopefully be making good headway on mine over the next few weeks so will make a thread to tempt you away from turbos!! Although this engine make 200+hp with a turbo :o
September 19th, 2013, 10:21 pm
The gearbox'll love that!
September 19th, 2013, 10:23 pm
I still not convinced it will agree with the 100! A nice Hewland would be perfect for big power :twisted:
September 19th, 2013, 10:28 pm
Could you find us a source of cheap Hewlands then please? :lol:
Adaptor plate is 12mm alu, and it would be no problem to make extra pieces at the side. Then I think you would need to bolt a steel bracket onto it to hold the rubber mount.
September 19th, 2013, 10:35 pm
I am first in the que if I find any! :lol: I work with Hewland products but don't think there is such a thing as a cheap Hewland gearbox.
I picked up a standard box today and flywheel so I can start making swarf soon!
September 19th, 2013, 10:42 pm
To be honest, a modified 2cv gearbox
thicker pime axle bearing holder
thicker (4x4) bearings at the back
a good vaccuum host with oilcatch tank
and the nut behind the wheel (who knows what he's doing someone like Pete Sparrow who strokes his car after it did a good job)
and it will be fine... :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
however I have also a lna gearbox with callipers already fitted
and a axel 1300 5 speed with ventilated disks ( I guess with 9200 rpm it will do 230km/h)......
So 1 of them should do the trick
September 19th, 2013, 11:07 pm
lpgo,
I don't think it's the bearings you need to worry about in a 2CV gearbox when subjecting one to about 3 times the original design's torque and power.
I've got the input shaft here from the BMW engined UK racer which finished 3rd at Spa 24hr a while back.
The bearing (*and the input shaft seal which I'd fitted at Snetterton after being awake for over 24 hours*) are still OK, but the sustained high contact pressure on the teeth has scuffed them.
* Rick also forgot to let me know where the input shaft was destined to be used, otherwise I'd have adjusted the fit to cater for use at over 8,000 rpm... * :roll:
September 20th, 2013, 1:08 am
If you're going to all the effort of achieving 100bhp+ then make your adaptor plate to fit a ford gearbox and Bedford Rascal/Reliant Rialto/AH Sprite axle. Rear wheel drive would be so much nicer.
September 20th, 2013, 7:19 am
Ken, my experience is just the otherway round.... Primeaxle plate (outside the clutchhousing) is bending all the way. Back bearings are weak, so simple but effective is to change them for a double rowed bearing (it fits perfecty when cutting the upper 3. gear tooth to 20.5mm (out of my mind)... I never experience tooth-wear :lol: when tooth are
positioned in the way Citroen intended).
P.s. a gearbox comming from the Citroen plant, misses up 0.5mm on all gears/or pignon and crown, so always re-messure and re-position them, (especialy when racing with them)...
@ Russel, I have never driven a rearwheeldrive car on personal basis; only (selfbuild 4x4) and frontdrive, so first corner and I probably will face the wrong direction.. :lol: :lol: :lol: :lol: :lol:
ken wrote:
lpgo,
September 20th, 2013, 7:21 am
Users browsing this forum: No registered users and 217 guests
