View unanswered posts | View active topics It is currently November 20th, 2025, 6:47 am
Reply to topic  [ 7 posts ]
 Dashboard Lamps
Post Dashboard Lamps
Combined Switch and Indicator LED.
Off Position.
On Position
Rear Fog, Brake Fluid maybe Direction/Hazard.
Makes space for some other indicator or switch.
September 15th, 2013, 12:58 pm
Post Re: Dashboard Lamps
Very neat a DIY job I guess ? I put a couple of Maplin toggle type LED switches in for heated rear screen and the demist blower motor. They were so bloody bright I had to put a couple of rubber caps over them, as they were blinding me :lol: :lol: :lol: :lol:
September 15th, 2013, 1:46 pm
ooh thats neat - how did you do it?
September 16th, 2013, 10:12 am
In Bits
LED and Resistor (1.8K larger value gives dimmer LED)
see LED resistor value http://led.linear1.org/1led.wiz
Both from EBAY
With Heat Shrink
Fitted inside the existing the cavity in the button
Fitted additional terminals, use fine wire inside switch as it has to be flexible
Hope this helps, picturtes are so much easier than words..
September 16th, 2013, 11:43 am
scared of the dark
I like that. Although would it not be easier to just fit a single extra terminal for the earthing as you've already got a switched positive there?
Some previous cars:
September 16th, 2013, 4:23 pm
Good point, but if you use a relay, allows the indication of the relay state.
September 16th, 2013, 8:11 pm
scared of the dark
Ahh yes, I thought it was a direct replacement for the original lamp using the original loom etc.
Next challenge is converting the twist switches ;)
Some previous cars:
September 17th, 2013, 10:20 am
