View unanswered posts | View active topics It is currently May 1st, 2026, 4:24 pm
Reply to topic  [ 7 posts ]
 2cv gearbox length
Post 2cv gearbox length
Hi,
Roughly how long in a 2cv6 gearbox? from front face of bell housing to most rearward point and also if possible the width between the drive shaft flanges. :mrgreen:
September 4th, 2013, 8:16 pm
Post Re: 2cv gearbox length
db78 wrote:
Hi,
<rummages in back of ill-lit shed>
From front of bellhousing to gearbox mount, about 450mm.
If you include the input shaft, more like 480.
Width - about 350.
September 4th, 2013, 8:54 pm
ive got a shorter one if you need it, only ran 23'35" since a re build, bell housing is a bit of a mess.
bit of an issue
September 4th, 2013, 9:46 pm
I wish I'd seen it go. Must've been like a grenade going off. Did you get all of the flywheel back? Could you weld it back together? No issues.
September 4th, 2013, 10:21 pm
cast so welding difficult "JB weld" is better! "As strong as a weld" and i can "machine and tap it just like metal" in fact im just going to buy 100 tubes and make a JB flywheel
September 5th, 2013, 7:58 am
Looks like a broken egg
September 5th, 2013, 8:16 am
toomany2cvs wrote:
db78 wrote:
Hi,
Width - about 350.
thank you :mrgreen:
impressive! but aslo gutted for you running so close to the finish..
September 5th, 2013, 7:14 pm
Users browsing this forum: No registered users and 98 guests
