View unanswered posts | View active topics It is currently April 27th, 2026, 11:55 pm
Reply to topic  [ 880 posts ]  Go to page Previous  1 ... 53, 54, 55, 56, 57, 58, 59 ... 88  Next
 1-2-spark
Post Re: 1-2-spark
Will look now cheers
August 30th, 2013, 4:45 pm
Post Re: 1-2-spark
@JamesWallace, a rusty pickup can't be the reason, when the problem occured did you have the laptop connected then?? or where you just driving along???
As Saurus says look to all wires and connections and look if they are correct.....
Look to the VR sensor wire, if something is wrong there.....
When iddleling on points, does the 1-2-spark yellow led flash?? does the red eror led come up (not good)
Can you hook up the computer and look if your numbers are right.....
please try to give more information.....
@ Saurus, I have my wires throwed into the enginebay, and it is working for over 2 years now.... but you are so right......
@ Harley I pm-med you, my streetname is like my..... it isn't that long..... :lol: :lol: :lol: :lol:
Hope your package will arrive........
August 30th, 2013, 4:46 pm
Post Re: 1-2-spark
Wires all appear fine
I need to test when home with a multimeter
Edit
Lpgo yes laptop connected at the time. Had been driving 2 h making tweaks
I also tried burning your table but ran the same .....
August 30th, 2013, 4:50 pm
Post Re: 1-2-spark
Orange flashes
No red led
I burned your table geo and it was no better just back fire bangs etc
August 30th, 2013, 5:00 pm
Post Re: 1-2-spark
Table i was on
Table i burned to try help my situation
Idles OK
August 30th, 2013, 5:26 pm
Post Re: 1-2-spark
Was it running ok before you started tweeks? Have you altered the dwell by mistake? or rev limiter?
August 30th, 2013, 5:34 pm
Post Re: 1-2-spark
Nope and nope
There was lots of exhast popping etc back firing
It was fine before i tweaked the advance but didnt do anything untoward.
Thats why i tried geo's table just to see
I tried for 10 mins adjusting it by advancing and retarding. Nothing i could do would help.
Mark if you read this can you send me print screen of my tables from that day we played with the car ..?
Cheers
No idea why it did it. Dwell etc was un touched
Maybe cos the engine was warm after 2h driving ..?
August 30th, 2013, 5:40 pm
Post Re: 1-2-spark
Please check your dwell anyway, (and other pages as well)......
Engine to warm can't be, when warm the only thing happens that it pinks/knocks earlier.....
When you run on points, and 1-2-spark connected to the computer is the rpm gauge ok or are there eratic spikes visible???? please check...
Please check also if the sensor is about 1mm from the pickup......
August 30th, 2013, 6:37 pm
Post Re: 1-2-spark
Must have done something - Can I ask why you were trying to tweek it??
Mine I just leave alone. Little knowledge can be dangerous ;)
August 30th, 2013, 6:41 pm
Post Re: 1-2-spark
Rev gauge fine on points
And was colder so wanted to adjust. I wasnt tweaking much at all
Will check dwell
Cant check gap but cant see it haveing move. It welded in place.
August 30th, 2013, 6:44 pm
Users browsing this forum: No registered users and 127 guests
