View unanswered posts | View active topics It is currently August 7th, 2025, 6:15 pm
Reply to topic  [ 3993 posts ]  Go to page Previous  1 ... 172, 173, 174, 175, 176, 177, 178 ... 400  Next
Slept in it as I got locked out of the house.
August 23rd, 2013, 12:32 pm
I've had that delight more than once. Good innit? Unfortunately this is no longer an option with the visa though, despite my best efforts I couldn't break into it whilst pissed the other week. Was waiting for someone to come back for two hours :(
August 23rd, 2013, 12:35 pm
I couldn't break into it whilst pissed (
Not a problem with a Méhari.
August 23rd, 2013, 3:57 pm
Been using it around Unst most days so far and it's turning into a celebrity. It shares the island with another classic, a Morris Minor Convertible.
August 25th, 2013, 3:05 pm
Went to a tractor show - some old cars also.
Check out the exhaust on the tractor - should have heard the noise - brilliant :D :D :D
August 25th, 2013, 7:41 pm
Wow a tractor that thinks its a Subaru :-))
August 25th, 2013, 8:21 pm
Today - Fitted CPD valve and an "uprated" speedo dash bulb, also cleaned fuel filter, fitted spring to heat exchanger, changed coil over, a general tidy up of wires under the bonnet then and went for a spin 8-)
*along with yesterday - had the "dim dip" removed, adjusted & modified accelerator spring, and reset timing* All thanks to Uncle Ken
The car has had a lot of attention the last few days 8-)
1988 2CV Special
1969 Singer Chamois
August 26th, 2013, 5:21 pm
Brill hope you checked the CPD valve was marked for flow the correct way as some had been marked wrong, mind the thread on that was a while ago. Hope you didn't lose to much skin off your fingers doing the speedo :)
August 26th, 2013, 5:26 pm
Was looking to use it for the 57mile/2 ferries drive to Lerwick today but the weather was bloody awful first thing this morning so used the C4. This afternoon the weather is superb for open-top motoring in a tin can, but it's 57miles and 2 ferries away. Bum! :( I'm booked on the 1805 and 1855 ferries back home so hopefully get it out for an hour this evening. :)
August 27th, 2013, 4:38 pm
Now your Lucky up in the north, having longer daylight (at the moment)
August 27th, 2013, 4:56 pm
