View unanswered posts | View active topics It is currently May 1st, 2026, 11:21 pm
Reply to topic  [ 4 posts ]
 Brake pipe connections.
Post Brake pipe connections.
Hi All
I know this has been brought up before regarding disc brakes.
Rear brakes to front connection and Front brakes to rear connection on master cylinder.
But on drum brakes on a Mehari is it the same rear to front and front to rear connections on master cylinder or vice versa.
Peter
August 18th, 2013, 8:44 am
Post Re: Brake pipe connections.
Peter,
Meharis are Dyane- based, so the connections to a dual circuit master cylinder are as you've described.
Note that if the linings on the rear shoes are not located symmetrically, those with the cutaway part should be fitted at the front.
Peterj wrote:
Hi All
Peter
August 18th, 2013, 10:58 am
Hi Ken.
Thank you for the reply.
Sorry for my late reply.
Its not a dual circuit master cylinder so it so it won't make any difference will it.
Regards Peter.
August 20th, 2013, 7:50 pm
Correct, with a single circuit master cylinder, the same system pressure is delivered to all slave cylinders simultaneously. :)
Peterj wrote:
Hi Ken.
Regards Peter.
August 20th, 2013, 11:42 pm
Users browsing this forum: No registered users and 119 guests
