View unanswered posts | View active topics It is currently May 1st, 2026, 8:50 pm
Reply to topic  [ 23 posts ]  Go to page 1, 2, 3  Next
 LED Bulb question
Post LED Bulb question
Just picked up a pair of LED H3 bulbs to replace the bulb in my Joey (Joey Deacon = Beacon). Now I know nowt about electrics, but when I connect the bulb I get the mearest flicker and then nothing.
Could they just be cheap and duff, or am I missing something?
http://www.ebay.co.uk/itm/2x-H3-9-SMD-5 ... 6186205%26
Ta
July 10th, 2013, 9:19 pm
Post Re: LED Bulb question
Does the beacon have a built in flasher?
July 10th, 2013, 9:28 pm
Possibly not enough power? We have started delving into LED street lighting at work and they're pretty sensitive.
July 10th, 2013, 9:35 pm
The joey is just a rotating mirror around stationary bulb. I wondered if power was an issue... there was me thinking 12V was 12V.
BTW would running a 6V bulb in it make it run hot and blow fuses?
July 10th, 2013, 9:38 pm
Try giving it some revs, maybe on idle the alternator isn't giving enough oooomph? I don't really understand electrics, despite technically being a 'lighting engineer'...
July 10th, 2013, 9:42 pm
No joy there Russ.
July 10th, 2013, 9:59 pm
Put a normal bulb in and accept that like me, you're not cut out for this shit.
July 10th, 2013, 10:04 pm
Believe me, from expensive purchases, the cheap LED lights are nothing but garbage and not worth bothering with - try and find high white normal filament bulbs instead...
July 10th, 2013, 10:35 pm
test the led,s on the car battery polariry has to be correct
July 10th, 2013, 10:45 pm
Polarity's the most likely problem. For an LED, it's important. For a halogen, it isn't. Probably the ciggy socket or plug are wired wrong-way-round. The centre prong has the fuse, so is the +ve, the side sprungyprongs are -ve.
H3s have a trailing wire - that's the +ve, with the body being the -ve. With that in mind, it should be easy to just bodge it to a charger or something to see if the LED itself works.
July 11th, 2013, 10:11 am
Users browsing this forum: Bing [Bot] and 91 guests
