Page 1 of 1
[ 5 posts ] |
gabrielcitro
 Nut bearing, wheel side.
Hello! I need to know how to remove this nut, exixste any special tools? You can check out any other way? Thank you very much.
| July 7th, 2013, 8:52 pm |
2CViking
 Re: Nut bearing, wheel side.
Remove the nut on the shaft and push the shaft out. Make a perfect fit rectangular piece of iron (will fit upright in to the slots) Shape an old socket by cutting a matching slot. Voila long extension and wrench, job done. (leave the peened over edges, will open when turning the ring nut)
| July 8th, 2013, 10:07 am |
2CViking
Forgot to mention, a bit of heat on the ring nut works wonders
| July 8th, 2013, 6:48 pm |
gabrielcitro
Ok. - I must first remove the nut ... I was sure it was the other way around! Thank you!
PS key Ua rare to get that nut at the bottom.
| July 9th, 2013, 3:45 am |
gabrielcitro
I made the tool to remove the nut that tightens the bearing (after upload photos). First could not draw with, but giving warmth to the body of porta bearing is loosened as by magic. - No've found at images the steps to do this in any forum, by what I will share with you how I did.
| July 14th, 2013, 4:07 am |
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: No registered users and 219 guests |
