View unanswered posts | View active topics It is currently November 20th, 2025, 8:13 am
Reply to topic  [ 29 posts ]  Go to page Previous  1, 2, 3  Next
 A Panel removal for cooling...
Post Re: A Panel removal for cooling...
Sean's post? ^^^^^^ ;)
"...the scoops then act to draw air out the engine bay. "
richardmorris wrote:
No ones mentioned the Venturi effect yet!
July 2nd, 2013, 11:31 am
Didn't Venturi Effect support A Flock of Seagulls on their 1984 tour?
July 2nd, 2013, 12:43 pm
Worth checking that the sound-deadener stuck to the inside of the bonnet isn't blocking airflow out of the venty-venturi-thingy-dents that are already in the A-panel. Usually, it is...
July 2nd, 2013, 1:36 pm
:lol:
:lol: :lol: :lol: :lol: :lol:
July 2nd, 2013, 2:35 pm
yes, but not by name :P
July 2nd, 2013, 4:32 pm
banjo wrote:
DSCF3535 by 2steamhorses(Bob), on Flickr
I shot this at Salbris a neat way of getting more heat out of the engine bay,the boot pretty cool to!!
A simulare setup made a 10°C difference on my oil temperature on the motorway in Serbia cruising 100/110 km/h with about 30°C ambiant temperature.
I think it works, cause I would think there is a depression behind the rear edge of the triangular panel (if that makes sense), sucking of air flow from under the bonnet. Otherwise the air is pretty much stuck between innerwings, panels, bulkhead and bonnet.
July 2nd, 2013, 9:49 pm
Makes sense.
July 2nd, 2013, 9:54 pm
Sean wrote:
and loose any under bonnet fluff that hangs down.
July 2nd, 2013, 9:55 pm
I guess that it will be easy to spot who's been reading this post in Spain then!!
Cheers for this tested info Bart.
July 2nd, 2013, 10:06 pm
Just for balance, I don't care either way.
July 2nd, 2013, 10:23 pm
