View unanswered posts | View active topics It is currently February 3rd, 2026, 6:34 pm
Reply to topic  [ 284 posts ]  Go to page Previous  1 ... 20, 21, 22, 23, 24, 25, 26 ... 29  Next
 LGY 275P Rises Again!
gym bunny
Post Re: LGY 275P Rises Again!
Just caught up on this. Looks like you are making good progress.
Wheel spacers are confusing me, how do they fit on the hubs? What studs are you going to use or fit? Weird. perhaps this would stop my tyres cleaning the exhaust and arms on half lock....
Your thread always makes me want to spend more time on Jeremy!
1299cc FTW
April 11th, 2013, 2:00 pm
Tim,
The spacers will fit up against the hub and behind the wheel, if you can picture that!? The 3 hole drilled in them match the 3 stud wheel pattern, but have had to drill them out slightly as they were to tight on the studs, also had to open up the holes on the inside as the new stud had a longer raised bit when they were fitted to the wheel hub, which meant the spacers would not sit flat up against the hub, but it does now!!
The studs were from a Volvo I think and r about 65mm long, almost double the original stud and fit perfectly into the hole, just need to spot weld them back in again!!, (i still have the invoice and can give details if anyone needs them)....it now should give plenty of room for the spacer and alloy and more than enough thread for the wheel nut to attach to..
Will set to getting them sorted in the next week or so..
Dyane 12 1976 (ish)
April 14th, 2013, 3:23 pm
We just used some suitable sized washers to slip over the studs on the rears of our old sidewinder to stop the wider tyres rubbing the inner wheel arches - still left enough thread on the wheel nuts to catch......
April 14th, 2013, 3:50 pm
Paul that probably works fine if you use standard wheels, but I've stupidly got those GS alloys on.... :roll:
It's right on the edge well fairly close at the moment and it doesn't get anyway near full lock before it hits the exhaust, hopefully 20mm spacers will stop this happening...
Dyane 12 1976 (ish)
April 14th, 2013, 7:37 pm
Ah.....forgot you had weird alloys....
April 14th, 2013, 7:38 pm
Actually been in the garage 2nite, haven't done anything useful really, just been arseing around with some paint, if you can see what I've done through the background of shite in my garage!!! :lol:
Got the summer hols coming up so will make my best efforts to get some mink done!! :lol: :lol:
Dyane 12 1976 (ish)
June 30th, 2013, 9:35 pm
A bit of a waste of 10 minutes but hey ho there are done now.. Might get round to fitting them next... :o
Dyane 12 1976 (ish)
June 30th, 2013, 9:49 pm
Work has started again today, abandoned the wheel spacer idea now, may be a project for much later :roll: :lol: after a bit of "should of thought of that earlier" we decided to modify the exhaust instead so it clears the tyre on full lock, after this our attentions were turned towards the engine, old one is out and the new/replacement one is being built back up and soon to be slotted in....but once removed we discovered the clutch fork spring return thingy was rubber ducked split into 2 pieces!! (See post in technical asking for replacement one)
Doing some more 2moro, should have engine completed with new belt, tensioners, etc and ready to put in car!!
I'll post some pics 2moro as I know we all like pics ;)
Dyane 12 1976 (ish)
July 25th, 2013, 6:46 pm
Eventually "dressed" the engine well got the important stuff on, and engine back in..
Just to find that the gearbox/drive was solid wheels wouldn't turn....bugger..... :twisted: :evil:
File comment: Engine out again then....FFS!!!!
Dyane 12 1976 (ish)
July 29th, 2013, 10:00 pm
Holy moly! Regardless of whether it works or not, that looks really impressive!!
How much of it is that engine I fetched from deepest Worcestershire for you?
July 29th, 2013, 11:17 pm
Users browsing this forum: No registered users and 217 guests
