View unanswered posts | View active topics It is currently June 19th, 2026, 11:47 pm
Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Brake centering tool
Post Re: Brake centering tool
I used a piece of flat bar bent at 90' with a slot like above and attached the end with the bend to stub axle with a jubilee clip,it rotates nicely round to check the concentric's of shoes to axle centers.
June 12th, 2013, 5:47 pm
I use an old alternator bracket welded to a rear hub nut with a hole drilled in the base of the strap to fit one of the front drum studs. Works for both front and back and cost me sod - all.
June 12th, 2013, 5:59 pm
I like the pipe fitting idea - any idea of diameter ;)
Cheers
June 12th, 2013, 7:33 pm
I'm look ing at making on next week, could possibly make another!
June 12th, 2013, 11:25 pm
If you are offering that would be great.
:D :D
June 13th, 2013, 6:51 am
Leave it with me, as its the next task on my list :D
Paul
June 13th, 2013, 10:09 am
1 3/8" or 35mm inside diameter for the pipe fitting.
June 14th, 2013, 9:31 pm
He's right you know :lol:
I'm searching our stores at work for some tube, then find some stainless bar to weld on.
Any other measurements available?
June 16th, 2013, 7:56 pm
Found a piece of stainless tube, the exact size required!
Just need to weld the slotted bar on ( when I find some?)
June 17th, 2013, 12:18 am
Made you one last night!
Stainless steel, work of art! :lol:
i must cost our company a fortune!!!!
Well to be honest, i found the material in the scrap bin,
Ive not tried it yet, as i don't have my new brakes, but the principle of using the axle as the center to rotate the guide round seems logical.
Ive slotted the bracket so theirs loads of adjustment.
If you can forward your address, ill post it on.
paul58@rock.com
June 19th, 2013, 1:06 pm
Users browsing this forum: No registered users and 230 guests
