View unanswered posts | View active topics It is currently May 1st, 2026, 7:21 pm
Reply to topic  [ 41 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Brake centering tool
Post Brake centering tool
What do you use :?:
I need a slightly better one than the one I made up. Mine are slightly out and I want to get it right.
Any pictures, links or drawings would be great
Cheers
Ian
June 11th, 2013, 8:22 am
Post Re: Brake centering tool
Front or rear?
June 11th, 2013, 8:49 am
Front for starters
(so there are two I need then :? )
June 11th, 2013, 3:59 pm
Yes, original tools are hard to find. Backyarders can use this tool front and rear
In short, leave the drum on. Bring the shoes out to near contact with the drum. Remove the drum without backing off the shoes (only possible without any lip on the edge)
Fit the centering tool and find the highest point. Set the tool on the highest point and begin centering by turning the lower eccentrics + the back adjusting bolts if needed.
Good luck
June 11th, 2013, 7:00 pm
Where can I get a big bolt like that - (I have the rest to make one up)
June 11th, 2013, 8:48 pm
What bolt?
June 11th, 2013, 8:53 pm
A piece of 10mm rod and a couple of nuts from brico will do
Cheers
Boggy
June 11th, 2013, 8:56 pm
Sorry NUT!!
June 11th, 2013, 9:32 pm
Thats the nut that holds on your rear hub!!
June 11th, 2013, 9:55 pm
I made this one out of an old pipe fitting - shame to use a nice hub nut !!
June 12th, 2013, 5:05 pm
Users browsing this forum: No registered users and 115 guests
