View unanswered posts | View active topics It is currently June 19th, 2026, 11:46 pm
 Fixings, bolts etc
Post Fixings, bolts etc
Not strictly A-Series, but does anyone know where I can get unusual fixings? I had to grind off some extra-long bolts from the rear shockers of an old Escort van, and I can't find replacements anywhere! Even Ford can't help!
June 4th, 2013, 10:43 pm
Post Re: Fixings, bolts etc
Checkout any local fixing suppliers if you know the thread size and spec you want they should be able to supply. Have you checked out any form for Ecsorts ?
June 4th, 2013, 11:13 pm
What size are they?
June 5th, 2013, 12:01 am
Not sure what size they are. I'll measure them next time I go to do some work on the van. They're unusually long (5-6 inches) but not threaded all the way along. The original nut is a weird square thing, which slotted into a kind of cup thing, but I knackered it (and the cup) when I had to grind it off to remove the shocker.
June 5th, 2013, 12:13 am
Cant you make something thatll do the job on a lathe?
June 5th, 2013, 9:00 am
In theory, yes!
June 5th, 2013, 10:24 am
Use threaded rod and 2 nuts ?
June 5th, 2013, 1:38 pm
minimum tensile strength for anything on a car is 8.8 shocker mounts are likley to be 10.9 threaded rod is often 4.chocolate or just "black iron" not really going to be suitable.
June 5th, 2013, 7:22 pm
Try these guys,they seem to stock everything and will post no problem
Cheers
Boggy
June 5th, 2013, 8:51 pm
Sorry Boggy, but I can't see a link. Can you repost?
June 5th, 2013, 9:12 pm
Users browsing this forum: No registered users and 227 guests
