View unanswered posts | View active topics It is currently May 1st, 2026, 11:23 pm
 6 Volt Regulator
Post 6 Volt Regulator
My regulator is playing up a bit, I sometimes have to trick it into operation by pushing the contact on the electro magnet. I am thinking it may be the charge in my battery not enough to close the contacts so I will see when I get it on the road.
But can my Ducelier 1283B be exchanged with a Ducleier 8304A. They look very similar but not sure if you can swap and change.
My Regulator 1283B
The one available on the Bon Coin 8304A
May 26th, 2013, 4:04 pm
Post Re: 6 Volt Regulator
Anybody have an idea :?: :?:
:D :D
May 28th, 2013, 10:15 pm
Give it a try. But keep running a meter across the battery as a test, if the charge is too much stop. If not you've solved your problem.
May 28th, 2013, 10:18 pm
Problem is I need to buy the other one first at €50.
Wanted to know before I send the cheque - it might be a try after you buy thing I suppose.
May 28th, 2013, 10:19 pm
Ah! Yes....No spares? No one near by to lend one. 50 euros...But you always need a spare.
6 volts can't damage a 12v regulator..
May 28th, 2013, 10:28 pm
The new one would be 6 Volts too.
I might just take the risk - they are supposed to match up with the Dynamo I thought, hence the question.
May 29th, 2013, 8:26 am
Yer cables look a bit thin - are they really ok for 21 amps ?
June 3rd, 2013, 5:42 pm
hmmmm, that could be something. I bought it like this BUT I am not sure it left the his barn since they did it. And I am certain it has not worked correctly since I bought it as I have never seen the ammeter move so thought it was the norm for it just to sit there in the middle.
I bought that regulator, awaiting the new battery and if no luck I will make up some heavier leads.
thanks for this :D :D
June 3rd, 2013, 6:33 pm
Time for today's lesson, in that case... :lol:
http://matchlessclueless.com/electrical ... ng-system/
June 3rd, 2013, 11:45 pm
Hi I picked a 6 volt Paris Rhone one up at vide grenier on Sunday. points box regulator and wiper motor, 3 euros for the three. Always good place to keep a look out for 2cv bits
Cheers
Boggy
June 3rd, 2013, 11:46 pm
Users browsing this forum: No registered users and 117 guests
