View unanswered posts | View active topics It is currently May 1st, 2026, 7:15 pm
 Steering judder
Post Steering judder
Friends 2cv judders going around corners
No idea how bad / scenario's but what could be the cause of this?
New king pin fitted which i did (as per viking'a guide. All was perfect (went through mot no problems) no play all as it should
Could it be wheel not balanced correctly? (New tyres fitted i think) or play in track rod end?
Mine also does it round courners on a rubbish road surface too
May 18th, 2013, 1:46 pm
Post Re: Steering judder
Poor surface could be inducing wheel patter, duff shocks or play in the shock mounts might be responsible - mounts unlikely if just mot'd but missing duff shocks on older cars is fairly common in my experience :roll:
More info needed.
m
Mike
May 18th, 2013, 2:07 pm
Missing duff shocks?
So its unlikely to be my kingpin then?
Im 100% confident in it
Yes mot
Recent. But you never know
May 18th, 2013, 2:17 pm
somethings worn or loose
KP, steering arm/track rod, shock, axle tube chassis bolts steering rack guide ring etc
new KP aren't always as tight as they should be out of the box
May 18th, 2013, 2:23 pm
Ok. Ill re grease, and check all of the above
Cheers sean
Ill report back
May 18th, 2013, 2:28 pm
Missing as in not noticing that there is a lack of damping rather than missing as in it fell off! :lol:
Painting them up so they are nice and shiney has been known to fool the mot man - not that I'm suggesting that anyone here would or should do that... Just saying.
Otherwise, wot Sean said.
m
Mike
Alternatively, if you have friction dampers that you have never got round to adjusting then you have as much damping as if the hydraulic ones HAD fallen off. It makes for entertaining driving, causes the front overriders to hit the ground every so often and the great unwashed to point and larf (more than usual) as you lollop down the road in a series of wobbly bounds...
Mike
May 18th, 2013, 2:33 pm
Well it was fine when it was parked in august last year after mot failure
I then did the kingpin in september and it sat until a week ago not moved and now it judders
Still certain in my kingpin being fine
May 18th, 2013, 2:47 pm
Check the track rod/ball joint endy thingies.....if it still looks round you might :?: get away with tightening it up a little,if theres any sign what-so-ever of it being oval then replace them ......'cos an "oval shaped/rugby ball" end wont function properly and you could snap the arm.
T.
2CV6 Special [Red]
C4 VTR+ Coupe [Black]
May 18th, 2013, 2:52 pm
Turning left or right maybe both?
Shockies or steering guide ring and/or housing buggered
May 18th, 2013, 3:02 pm
Users browsing this forum: No registered users and 108 guests
