View unanswered posts | View active topics It is currently May 1st, 2026, 11:24 pm
 Driveshaft - Universal joint
Post Re: Driveshaft - Universal joint
OK I need both hubs including brake backing plate and complete drive shafts except the wheel side drive shafts
May 5th, 2013, 10:27 pm
I will do that bit, they went in fine and came out fine. I don't want to start taking all those a part again.
It is just the driveshaft part. If they are damaged i will go for new ones or a decent set of second hand ones.
May 5th, 2013, 11:15 pm
Got your inner drive shaft forks. Sadly the cross joint we ordered are no good. They are simply to wide. When both securing clips are fitted, the joint can't turn due to too much pressure on the needles inside the caps. The design is not correct. I need to find some original or maybe file these reproduction cross joints. I think I can file the internal stub a fraction allowing the caps to move just enough so the biting disappears. Failing that, other cross joints are needed. Maybe Cassis can supply a better product
Back soon
May 13th, 2013, 9:22 pm
Yes, I had the same problem and had to rub the circlips down on emery cloth to get a few thou end float. Also see my previous forum on how one of these copy joints snapped under emergency braking. I have a pair of genuine Citroen joints still in their boxes, but with post from France, you probably wouldn't be interested.
Bob
May 14th, 2013, 7:55 pm
Bob
We are in France (56), price please
Cheers
Peter
May 14th, 2013, 8:00 pm
If you still have a need for joints try these guys, very helpful.
http://www.davemacprops.com/DMPHOME.html
May 14th, 2013, 8:11 pm
Been on the road for a few days (last 4 days 530 km on the bike.... Legs hurt)
Don't worry about the post costs, let us know. This is the last piece I need to get this little van back on the road.
Cheers
Ian
May 15th, 2013, 8:41 am
Bob
Any news please?
May 16th, 2013, 7:15 pm
Thanks for your PM Bobh. I do want them, please tell me how to pay. It is urgent now
Ship to
2CViking-France
14 rue du 19 mars 1962
56490 MENEAC
France
Thanks for your assistance
Peter
May 17th, 2013, 6:55 pm
Lovely the goodies arrived and it is original cross joint, paradise. Thanks Bobh
When the original is under pressure, they still turn where the reproduction bites
May 22nd, 2013, 8:23 pm
Users browsing this forum: No registered users and 118 guests
