View unanswered posts | View active topics It is currently August 16th, 2025, 12:55 pm
Reply to topic  [ 7 posts ]
 Rev Counter
Post Rev Counter
Hi
Any ideas on how to fit a rev counter and which one to get.
Don't want to over rev my Visa engine
May 7th, 2013, 5:36 pm
Post Re: Rev Counter
I bought this one and worked straight away. Just connect to coil etc..
http://www.ebay.co.uk/itm/52mm-White-Fa ... 5655de54c7
May 7th, 2013, 5:51 pm
I walked into a bike shop and bought a Harley Davidson tacho over the counter much cheaper than I found on Ebay, $AU40, full size 90mm, easy to wire in.
Harley Davidson Tacho
Smaller tachos start to loose resolution and accuracy I believe.
May 7th, 2013, 6:31 pm
Kit,
one of these will also keep track of when you need to service the engine.
It shows 'hours run' when the engine's stopped, then automatically switches to tachometer mode as soon as the engine's running.
There's no wiring to sort out, just wrap the end of the trigger wire around one of the HT leads.
http://www.ebay.co.uk/itm/Spark-Plugs-E ... 3a7b1eaedc
May 7th, 2013, 7:24 pm
ken wrote:
Kit,
I use a similar one on my 2CV. Only issue with it is there is no backlight.
May 7th, 2013, 8:02 pm
The old Harley ones have a nice feel about them, much more "period" than some modern stuff
cheaper in the UK occasionally
http://www.ebay.co.uk/itm/Harley-Davids ... 4cff34a3dd
May 7th, 2013, 8:14 pm
I bought a used Stack tacho on eBay last year and its brilliant. It has a shift light and a telltale button. I'd reccomend it over cheapo eBay items.
May 7th, 2013, 9:53 pm
Users browsing this forum: No registered users and 22 guests
