View unanswered posts | View active topics It is currently June 20th, 2026, 12:01 am
Reply to topic  [ 6 posts ]
 Brake pipes
Post Brake pipes
Hi all, I'm after diagrams/pictures of the acadiane prake pipe system from the master cylinder to the rear brake pipe union. I know there are two seperate pipes which go through a load compensator(?). But I have no idea what it looks like or where it is fitted. Not to mention where I can get my paws on one.
Help much appreciated.
May 5th, 2013, 9:53 pm
Post Re: Brake pipes
http://www.mcda.com/154-tuyauterie-freins-mehari?p=2
Does this help? plus page 1
May 5th, 2013, 10:25 pm
Just ignore it.
May 5th, 2013, 10:34 pm
If you do ignore it, best to use *2CV size rear wheel cylinders and make sure that you connect the brake pipes at the master cylinder 2CV style, not reversed as they would have been with the brake limiter in place.
http://www.ecas2cvparts.co.uk/-c-38_49_50.html
* 16mm diameter, not 17.5mm
2CViking wrote:
Just ignore it.
May 5th, 2013, 11:22 pm
thanks much!
May 5th, 2013, 11:41 pm
Haggis Muncher
2CViking wrote:
Just ignore it.
Yup, that's pretty much exactly what my one looks like!
I'm planning a brake overhaul soon - might see if i can actually get mine working the way it was intended...
May 9th, 2013, 1:50 pm
Users browsing this forum: No registered users and 223 guests
