View unanswered posts | View active topics It is currently November 20th, 2025, 6:03 pm
Reply to topic  [ 3 posts ]
 Brake Fluid Level Warning Light
Post Brake Fluid Level Warning Light
So, my Mehari has a standard late brake fluid reservoir with the little nib on top that you push in to see if there's enough brake fluid.
There's two wires coming off terminals on the cap which I presume are to do with a low fluid level warning lamp.
My problems:
1) I can't find a low brake fluid warning lamp on the dash of the Mehari.
2) On the switchboard there is a button that you press to see if the warning light (which I can't find) is working - the switch has three terminals on the back.
Pressing the switch does nothing.
3? Could it be an illuminated switch?
So, could I just remove the terminals from the reservoir cap and hope that the tester doesn't feel the need to check for a fluid level warning lamp?
Make sense?
April 28th, 2013, 12:24 pm
Post Re: Brake Fluid Level Warning Light
Ok, ignore this, I pulled all the wiring out and re-did it from scratch. Problem solved :D
I have a working low fluid level warning light and you can test the circuit by pressing the button on the dash.
April 28th, 2013, 3:33 pm
<slightly baffled>
Umm, care to explain that?
My problems:
It's the one that lights up when you push the top of the float down, simulating low fluid level, and causing the terminals of the float to pass current.
April 29th, 2013, 10:49 pm
