View unanswered posts | View active topics It is currently June 19th, 2026, 6:57 am
Reply to topic  [ 4 posts ]
 Steering column Bolt at clamp......
Post Steering column Bolt at clamp......
This bolt should pop out ....right ??
Bolt was tight, but is now turning in the clamp but will not come out, even with some hefty taps with a "persuader". Should I hit it harder or just cut it....?
March 13th, 2020, 9:20 pm
Online
Post Re: Steering column Bolt at clamp......
The clamp at the bottom ? I guess. ( 13 in the picture )
Cut it, buy a new one .https://www.burton2cvparts.com/media//s ... rkolom.jpg
https://www.burton2cvparts.com/bout-z-kant-tapbout-2186
March 14th, 2020, 8:26 am
I'm not convinced cutting it is going to help you get it out. Try pulling the column up a smidgen.
March 14th, 2020, 12:33 pm
Just make sure that the bolt is aligned with the slot on the steering shaft before you try the withdraw it.
On refiting pay attention:
The screw of the clip connecting the steering wheel and pinion in the engine compartment, has to be completely removed now (not only loosen the screw).
When assembling the steering, those screw has to be tightened carefully!!!! The nut is a self locking model and the clip should not be disorted while fixing the nut, which could cause the cracking of the steering column!!!.
Thanks to Walter, who has published an article at the German 2CV magazine Entenschnabel about that serious problem.
http://www.entmontage.de/
I've Been Wrong Before.
March 14th, 2020, 1:08 pm
