Page 1 of 1
[ 4 posts ] |
Speedometer interchangabilty
turbofiat124
Joined: August 31st, 2016, 12:12 pm Posts: 322 Location: Hawkins County, TN. USA
I hope this doesn't sound like a dumb question but can I swap out my Veglia speedometer/instrument cluster in my 2CV6 that reads in KPH to MPH without having to replace the gear drive in the transmission? I would imagine the only difference between a KPH and a MPH speedometer are the numbers. But would the odometer be accurate? Or would it be off by .6 ?
I've seen some on Ebay.UK. Some are made by Veglia and some by Jagger. Is there a difference? Otherwise they look the same to me.
_________________ http://s222.photobucket.com/user/turbof ... t=2&page=1
| September 26th, 2016, 12:14 am |
AZL57
 Re: Speedometer interchangabilty
i don't think there any problem in switching the speedos. And the maker is Jaeger. You can use Veglia or Jaeger i think citroen did use whatever was cheaper or available. Some times due to strikes in several factories. So i had a Landrover that had a french ducellier ignition due to strikes at Lucas.
| September 26th, 2016, 8:27 am |
bobh
I swapped out a 425 engine and Traficlutch gear box for a 605 engine and later gearbox on my AZU 250. the speed reads high by about 10 Kph.
| September 29th, 2016, 7:23 pm |
AZL57
of course they have different gearboxes. But the 2cv6 ones should be interchangable.
| September 29th, 2016, 9:07 pm |
Page 1 of 1
[ 4 posts ] |
Users browsing this forum: No registered users and 207 guests |
