View unanswered posts | View active topics It is currently June 20th, 2026, 12:32 am
Reply to topic  [ 6 posts ]
 Tie rod adjuster
Post Tie rod adjuster
Ken's post in setting the ride heights properly has forced my decision to do it properly on my drummer.
What tool do most people use? Graeme Seed doesn't make the tool anymore, and I don't really fancy spending £30 on the fancy ratcheting spanner at ecas.
June 15th, 2014, 9:50 am
Post Re: Tie rod adjuster
Mole grips, if you're lucky a 9mm spanner or if the gods are really smiling on you they'll turn by hand.
June 15th, 2014, 11:00 am
I was lucky, mine turned by hand, everything on the car had been greased on a regular basis, looks horrible but nothing seized.
live life to the full, it can end so suddenly.
June 15th, 2014, 1:30 pm
Use 2 spanners size 9 at once to spread the load.
If a mole gripe is absolutely necessary, i usually put them on the ring beside the spanner place (the friction weld?) to prevent the rest of the rod from being damaged.
But if everything is okay, it should be possible to turn them by hand.
June 15th, 2014, 3:07 pm
They're a bit sticky, I'll just struggle on with mole grips. Thanks chaps.
June 15th, 2014, 3:10 pm
Always worked for me :)
June 15th, 2014, 8:23 pm
