60mph+ left hand vibrations?
Little Louis
So I'm on a dual carriage way and doing 60 or 70 is on a long sweeping left hander and the steering wheel starts to vibrate like fuck, it's like driving down a cobbled street, reckon it needs a new rack rod end lever arm?
| June 3rd, 2012, 12:07 am |
knightley
Joined: June 19th, 2010, 8:40 pm Posts: 761 Location: Kingswood, S.Glos.
 Re: 60mph+ left hand vibrations?
Ours did that. A new kingpin cured it.
_________________ John Jordan
| June 3rd, 2012, 12:08 am |
Little Louis
Kingpin appears to be fine, as it should be only changed 3-4000 miles ago.
| June 3rd, 2012, 1:02 am |
Nelsthebass
Wheel bearing?
| June 3rd, 2012, 1:19 pm |
Little Louis
will that be evident when I jack it up? I believe that was changed at the same time as king pins.
| June 3rd, 2012, 1:23 pm |
Nelsthebass
if you jack it up and hold the wheel at something like 10 past seven and give it a good old wobble you should be able to see if something is amiss....
| June 3rd, 2012, 1:28 pm |
Little Louis
Ok will jack it up and grease everything on Tuesday, I guess then we'll see what it is.
| June 3rd, 2012, 1:34 pm |
meshking
Does sound a similar noise on my old white 2cv, in which I replaced king pins (still there), then control arms (a little better) then had the rack reconditioned. There is a little bush inside that wears out and can cause clonking, but I don't recall if that's shown n long curves. I'm thinking first check the lever arms.
| June 3rd, 2012, 2:00 pm |
48pop
Joined: May 23rd, 2011, 7:14 pm Posts: 309 Location: ecosse
See here.....Identical problem.... viewtopic.php?f=7&t=3550Sean replaced kingpin, good s/h steering arm, and accurately adjusted track rod end, problem solved
| June 3rd, 2012, 3:01 pm |
Little Louis
No play whatsoever at all NON in either of the wheels when jacked up, so does that point to track rod lever arm?
| June 5th, 2012, 6:58 pm |
Users browsing this forum: No registered users and 7 guests |
