Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
 145 Tyres hitting swing arms
Post 145 Tyres hitting swing arms
So I trial fitted the 145s on the Van today and on full lock, the tyre sidewall squeaks against the swing arm.
Should I worry about this? It's not like I'm gonna be driving on full lock a lot is it.
March 24th, 2011, 10:21 pm
Post Re: 145 Tyres hitting swing arms
It ain't going to do the tyre much good if you do go lock to lock. There is a stop adjuster to prevent this. Just wind it out a bit.
March 24th, 2011, 10:32 pm
MOT fail. At least I had one fail on it. Just wind the lockstop out a bit.
March 24th, 2011, 10:34 pm
It's also an MOT fail..
March 24th, 2011, 10:35 pm
Just the fact it was a 145 tyre would fail a French CT, touching or not touching.
March 24th, 2011, 10:36 pm
Really? why's that?
Is that the massive nut on the side of the King Pin houseing?
Am I ok to run 145's? It's not dangerous or anything?
March 24th, 2011, 10:54 pm
Really? why's that?
They are very fussy about a vehicle having the correct specification tyre on. When 125's became difficult to get my local CT station took advice from the DRIRE [people who make and enforce the rules] as to whether he could pass my car on 135's. They could and now do.
March 24th, 2011, 10:58 pm
Really? why's that?
Look at the tyres on my car...
It's the not-very-massive-at-all-bolt on the end of the arm, yes. Look at it when you turn the steering onto full lock and you'll see what it does.
March 24th, 2011, 11:07 pm
Does anyone on here run 145's on a standard suspension?
Wondering how they behave.
In theory, straight-line grip should be improved, but not sure about in sharp corners where the geometry might affect it? Or are they susceptible to tram-lining even on the straight?
March 26th, 2011, 5:43 pm
I have done, and to be honest, there's not much difference in how it feels if you drive it about like a granny, if you rag the tits off it I found it had a bit more grip, but wasn't as nice as a 125 was for lightness of steering and actual handling.
March 26th, 2011, 9:47 pm
