View unanswered posts | View active topics It is currently April 29th, 2026, 4:28 pm
 Clutch cable adjuster thread
Post Clutch cable adjuster thread
Anyone know what thread the adjuster barrel on the clutch cable is?
January 28th, 2011, 7:16 pm
Post Re: Clutch cable adjuster thread
Might be completely wrong but I think one is 22mm the other 19?
January 28th, 2011, 7:47 pm
You are wrong - they're 19mm and 16mm - and it's the thread I'm after, not the spanner size. But thanks anyway. :lol:
January 28th, 2011, 7:49 pm
LOL. This is what happens when you know literally feck all about anything vaguely mechanical, and then think you actually do.
January 28th, 2011, 8:00 pm
M12x 1.0 I think
January 28th, 2011, 9:14 pm
That's the one...
Are you in need of a nut, RT? ;)
Sean wrote:
M12x 1.0 I think
January 28th, 2011, 10:27 pm
Yes, sort of ... wot I'm trying to do is extend the adjuster barrel because it's the easiest way of extending the cable outer to make an Ami 8 cable fit an Ami 6 with the old type pedal assembly. I've done this by cutting an adjusted off an old cable, but now I need some kind of arrangement to hold it all together.
... I'll post some pictures when I get chance. They're so much better than words. :)
January 29th, 2011, 12:10 pm
I suppose I should really have titled this "clutch cable adjuster thread thread". :lol:
January 29th, 2011, 12:18 pm
I reckon you may be best off buying an Ami8 pedal box. You'd be able to do away with that wafty crank thing I made for the throttle linkage too. Not sure if the master cylinder would fit though.
January 29th, 2011, 12:19 pm
weld a gearbox mount spacer on the bulkhead or just use cable tension to keep it there?
adjust by adding some seatbelt anchor spacers?
January 29th, 2011, 3:24 pm
Users browsing this forum: No registered users and 84 guests
