Page 1 of 1
[ 5 posts ] |
acadiane drivers door lock
ginger bloke
The push button on my acad drivers side door lock has broke. On removing the door panel I have noticed a small spring has broken and this is what returns the push button to it's original position. My problem is I can't seem to get the lock out of the door itself to have a proper look. Do I have to remove the whole window mechanism to get it out(it has posh wind windows). cheers ps all this hassle for a 20p spring
| June 6th, 2010, 4:11 pm |
Neil
 Re: acadiane drivers door lock
Had the exact same problem on mine, Graham. The spring snapped & the button did nowt & i couldn't keep the door shut.
I ended up drilling out the 2? pop rivets the hold the window channel to the frame, then removing the glass. I think the problem was i couldn't undo one of the two nuts that hold the handle to teh skin. Whether or not this is the best way to do it, i don't know!
| June 6th, 2010, 4:25 pm |
ginger bloke
ok cheers Neil. where did you get the new spring from?
| June 6th, 2010, 8:07 pm |
Neil
ginger bloke wrote: ok cheers Neil. where did you get the new spring from? My dad. Although, i've got two Dyane front door lock mechs sat on the shelf in the shed, which i forgot i had until after he'd hunted high & low trying to find a decent spring. If you get stuck, let me know & i'll stick one in the post.
| June 6th, 2010, 8:12 pm |
ginger bloke
sounds like a top dad  and thanks for the offer I'll let you know
| June 6th, 2010, 8:53 pm |
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: No registered users and 67 guests |
