Paul Narramore
Joined: November 16th, 2009, 10:14 am Posts: 211 Location: Aylesford, Kent
 Sidewinder
Just curious. I understand that a 'Sidewinder' is the name given for a 2CV/Dyane fitted with an 1100cc/1300cc Ami engine. How easy is it to fit to a 2CV?Dyane (presumably as it's a four cylinder engine, it'll project further into the front?), and is it usual for the combined engine/gearbox from the Ami to be fitted or will the Ami engine happily mate with the 2CV/Dyane gearbox?
I've no interest in modifying mine but simply interested.
| May 19th, 2010, 11:37 am |
SteveQ
 Re: Sidewinder
I'm sure someone who knows more than I will be along shortly... but as far as I'm aware, it's not just a case of fitting a GS/GSA engine to a 2cv. In general, they're body swaps - putting a 2cv or Dyane shell onto Ami super running gear. Which gets you a stronger chassis, designed for the flat four, and anti roll bars and stuff.
I think most folks use the ami super 4 speed. I think the GS 4 speed is larger, and I'm sure the 5 speed is.
Seems to fit nicely on a Dyane, 2cvs need some work. The original "Sidewinders" had an "interesting" bonnet bulge thing. Or you can do things with fibreglass - like on Tim's van...
I've seen a 2cv with a GS motor, where some subtle cutting of cowling and wings had squeezed the motor in, leaving things looking pretty much stock. Which was nice...
| May 19th, 2010, 12:03 pm |
PeteMcFlurry
Joined: April 2nd, 2009, 1:29 am Posts: 354 Location: Yorkshire
 Re: Sidewinder
GS motor tends to require a stretch at the front end a little...
_________________ http://www.flickr.com/photos/squareoftheyear
| May 19th, 2010, 12:25 pm |
4x4 SuperFinn
Joined: February 13th, 2009, 10:34 am Posts: 584 Location: Franken, D
 Re: Sidewinder
Paul Narramore wrote: Just curious. I understand that a 'Sidewinder' is the name given for a 2CV/Dyane fitted with an 1100cc/1300cc Ami engine. How easy is it to fit to a 2CV?Dyane (presumably as it's a four cylinder engine, it'll project further into the front?), and is it usual for the combined engine/gearbox from the Ami to be fitted or will the Ami engine happily mate with the 2CV/Dyane gearbox?
I've no interest in modifying mine but simply interested. My old Sidewinder Van was Ami Super Chassis, Acdyane body, GSA1300 engine, and 5 speed GSA box with a bit of rust thrown in. I did the engine and box change once which was easyish as the work had been done before but to start from scratch the issues as I see them would be getting the wiring loom right so it runs, cooling the brakes so it stops, getting the drive to the wheels as a GSA box uses different driveshafts. Making it look neat on the outside is up to personal preference!!
| May 19th, 2010, 1:26 pm |
toomany2cvs
 Re: Sidewinder
SteveQ wrote: In general, they're body swaps - putting a 2cv or Dyane shell onto Ami super running gear. Which gets you a stronger chassis, designed for the flat four, and anti roll bars and stuff. Quote: Yup. Bigger springs, non-interlinked front-rear suspension etc. Generally far, far beefier. The G motor fits very differently, too - the engine mounts are at the rear, where there isn't normally a crossmember on a 2cv chassis, and the exhausts are under the heads. Quote: I think most folks use the ami super 4 speed. I think the GS 4 speed is larger, and I'm sure the 5 speed is. The 5spd has a bit more protruding to the rear. The Ami & G 4-spds are the same casing, but the Ami has a shorter bellhousing and input shaft.
| May 19th, 2010, 5:28 pm |
Russell
 Re: Sidewinder
Been there, had one, got the T shirt. there's no point any more. Joolz proved that to us all last week. In it's time, yes, the best way of making a 2cv fast, but simply finding the parts nowadays is a hassle. *This* is the way forward:
| May 19th, 2010, 6:56 pm |
Paul Narramore
 Re: Sidewinder
A BMW R-series 'oilhead' 1100/1150/1200 engine presumably attached to the 2CV gearbox. Any probs with that? Very good engines.
| May 19th, 2010, 7:34 pm |
Jonathan
 Re: Sidewinder
BMW 1150, mated to a Citroen LN 'box.
| May 19th, 2010, 7:45 pm |
louise2cv
 Re: Sidewinder
Isn't sourcing gearboxes going to be a problem? Are there enough suitable ones about?
| May 19th, 2010, 7:54 pm |
Little Louis
 Re: Sidewinder
seems to be just it'll cost a bit and more seen as some hooligans in 4x4s keep blowing them up.
| May 19th, 2010, 7:59 pm |
Users browsing this forum: No registered users and 88 guests |
