2CV engine with Visa Barrels, heads etc
Roger V
 Re: 2CV engine with Visa Barrels, heads etc
| November 9th, 2023, 1:36 pm |
Ianredspecial
How on earth did you find that?
| November 9th, 2023, 11:17 pm |
Roger V
@Ianredspecial A Bedouin came up for sale on FB. It was a bit of a dog, but cheap. I did say if he ended up scrapping, I would be interested in the Bonnet. As it turned out, he appreared to have a spare bonnet. !!!
| November 10th, 2023, 3:19 pm |
Roger V
The starter kit has arrived. I need to get the fylwheel nut un done, and the crank is turning!
| November 10th, 2023, 3:21 pm |
Roger V
Ok, got over that hurdle  my mate Jenks turned up with one of those torque thingy's. Took about 5 seconds. A screw driver wedged behind the flywheel, and a smack on the crank with a copper malllet, and the fly wheel came off. And then it rained. So I shall do some more air filter box design
| November 10th, 2023, 5:14 pm |
Roger V
The Bonnet arrived  It looks ok  Took it over to the garage the Shed is in. Tried to start the Shed, but it wasn't having any of it  Took the battery out and brought back to put on charge. Also took the leisure battery out of the van for a charge up. I'm considering using the leisure battery for the Gen and lighting in the garage.
| November 11th, 2023, 5:39 pm |
AZL57
Otherwise you can put a belt on de the generator and hook it up to the 2cv engine...
| November 12th, 2023, 12:18 am |
Roger V
@azl57 It did occur to me
| November 12th, 2023, 8:36 am |
Roger V
So, a bit of progress on the Gen front ... Starter motor installed (doesn't quite fit by 1mm, but filed out).  It now cranks  All the wiring is pulled out to rewire! Thats progress right!
| November 12th, 2023, 8:08 pm |
AZL57
nice.... all that you pull out can't cause a problem..
| November 12th, 2023, 11:00 pm |
Users browsing this forum: No registered users and 224 guests |
