2CV engine with Visa Barrels, heads etc
Roger V
 Re: 2CV engine with Visa Barrels, heads etc
I'm looking to build an Engine Test Rig Tool Chest/Trolley will park underneath
| September 9th, 2023, 10:51 pm |
Roger V
Angle iron for the main part of the rig is ordered.  The idea is it will be on castors. I bought the tool trolley, and it arrived damaged, Had choice to return, but I negotiated a partial refund. A block of wood, and a few smacks with a hammer and it's fine now.  No further progress on the engine as life got in the way  It's just a case of further cleaning, sort out some gaskets, and reasemble. Unfortunately, some more life is about to get in the way, but watch this space  Edit Oh!, and I've ordered a surge tank from China, with a view to 2CVi.
| September 11th, 2023, 1:00 pm |
AZL57
I have a bell housing bolted on a frame. There you can hang the engine on and a starter motor.
| September 11th, 2023, 9:55 pm |
Roger V
Yes, good point, and I did think of that. But thought this may give a longer/wider wheelbase. Probably over thinking it a bit
| September 11th, 2023, 10:24 pm |
Roger V
I like your ideas, please keep posting
| September 11th, 2023, 10:44 pm |
48pop
Joined: May 23rd, 2011, 7:14 pm Posts: 309 Location: ecosse
Friend of mine makes these engine yokes for VW/Porsche engines......Slots into a standard Machine Mart stand. Allows the engine to be rotated and the casing split !
He also does a version with a starter motor mount.....
| September 12th, 2023, 10:03 am |
Ianredspecial
How clever is that.
Roger V
OK, so thats some bits of iron stuck together  there are plates on the bottom for some castors
| September 24th, 2023, 8:41 pm |
Roger V
Some progress
| September 25th, 2023, 3:02 pm |
AZL57
Some diagonal braces would be safe i think. The 2cv engine is normally build on it's side, bolted on to an holder. The did the same in the factory.
| September 25th, 2023, 5:00 pm |
Users browsing this forum: No registered users and 225 guests |
