View unanswered posts | View active topics It is currently May 1st, 2026, 10:50 am
Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 9  Next
 Battery Cables, + fuel pipe question all in one go
Post Re: Battery Cables, + fuel pipe question all in one go
Jameswallace wrote:
now, ive mever understood bolts etc, i get it when its in mm and inches, but what does it mean by m8, i know thats 8mm cos it says, but why m8??
If you refer to a "8mm" bolt, are you talking about a bolt with an 8mm head, or a bolt with an 8mm thread? M8 refers, unambiguously, to the thread size. (Well, apart from the thread pitch...)
If you think primarily in terms of 8mm, you might be thinking of the hex head size, which is usually M5 thread - and you might go and do something daft like buy threaded studding off fleaBay that's 3mm bigger than you really want, so will require _yet_ more back-figuring to try to get a half-arsed bodge to fit rather than admit you've cocked up...
But that'd just be silly, wouldn't it? And you're not silly, are you, James?
December 2nd, 2010, 9:40 pm
what size is the pipe, is it 6mm, and where can i get the correct sleaving for the pipe, / a alternative good job
ive searched and not had much success (dont really know what to search for, wording etc)
so, making it simple,
the 8mm nut there will go on that thread m8?
December 2nd, 2010, 9:42 pm
No.
December 2nd, 2010, 9:44 pm
ok ta
so what m is the rod
December 2nd, 2010, 9:47 pm
Luke wrote:
I used to have a larger battery on my 2cv - it came off a berlingo, and it was free :) I seem to recall it had much the same footprint, but was slightly taller. The rods weren't quite long enough for that, but by taking the springs out, I could *just* get it to do up.
I found a Xsara HDi circa 2000 did the trick. Higher amperage, fits in the tray and the terminals are the right way round
December 2nd, 2010, 9:51 pm
Didn't you fit a tow bar to your car.l I reckon it would be easier to buy http://shop.ebay.co.uk/?_from=R40&_trks ... Categories
from Ebay, fit it with the new battery you have and install a battery charger in the boot to charge your old battery as you go along.
December 2nd, 2010, 9:52 pm
maybe this bigger battery may sort my problem with the charging my phone out
only one way to find out
:lol: 250 brilliant!
December 2nd, 2010, 9:53 pm
There's a somewhat less than subtle hint in my post at the top of this page...
December 2nd, 2010, 10:02 pm
oh shit sorry, i only read the first bit, i had to google the word unambiguiusly and then didnt read the rest
sorry
is shall get my rear end down homebase and see what i can do
December 2nd, 2010, 10:04 pm
simplest way to think of it as what size hole will it go through?
M8 goes through a 8mm hole, M7 - 7mm, M6 - 6mm etc
the clue is in the name
December 2nd, 2010, 10:10 pm
Users browsing this forum: No registered users and 80 guests
