2CViking
 Re: Sticking Gearbox
Tripyrenees wrote: I can't make it to that one as our work season starts.
Do you know anyone that can do a full revision on mine. - I can be without it for a week or so. You are welcome to ship the box to me (clean) It is a day job depending what needs doing. Need to strip it down to find out. You need to find a transport company to deliver both ways Cheers Peter
| April 1st, 2013, 9:51 pm |
samfieldhouse
Do you know anyone that can do a full revision on mine. - I can be without it for a week or so. There is only one person I'd recommend 2CViking wrote: You are welcome to ship the box to me (clean) It is a day job depending what needs doing. Need to strip it down to find out. You need to find a transport company to deliver both ways
| April 2nd, 2013, 11:13 am |
toomany2cvs
2CViking wrote: It is very risky business to install a used gear box without knowing its past. There is a reason why it was removed. 90%+ certainty that the reason is body/chassis rot. Given the speed with which a gearbox can be swapped, I'd always just try a believed-good used one first. BUT DEFINITELY NEW OIL. Drain it before you fit it, then new oil before starting, and a change-when-hot after a few hundred km.
| April 2nd, 2013, 12:22 pm |
2CViking
toomany2cvs wrote: 2CViking wrote: It is very risky business to install a used gear box without knowing its past. There is a reason why it was removed. 90%+ certainty that the reason is body/chassis rot. Given the speed with which a gearbox can be swapped, I'd always just try a believed-good used one first. BUT DEFINITELY NEW OIL. Drain it before you fit it, then new oil before starting, and a change-when-hot after a few hundred km. Not true. I have around 20 425 gearboxes collected over the last 4 years. None of them were fit enough to simply stick clean oil in and off you go. They all had all sorts of problems needing fixing before running properly. If one is brave to just stick another box in, at least remove the lid and rear cover. However if one doesn't know what to look for, it is pretty pointless.
| April 2nd, 2013, 12:49 pm |
Tripyrenees
Joined: December 17th, 2012, 10:03 pm Posts: 966 Location: Luscan, Pyrenees, FRANCE
I am going to take the lid off and take a good look and work out the operation so I know what is going on for myself. Then I will try and figure out how to get the Box to 2CViking. How much does just the box weigh I wonder
| April 2nd, 2013, 3:28 pm |
lpgo
| April 2nd, 2013, 5:08 pm |
Tripyrenees
Looks like I will be shipping my gearbox for repair. Cannot find anything obvious that is wrong (broken bits in the bottom of the box). Think I have found the source of the oil in my clutch though - seems to have all exited through the top plate of the gear box.  Hardly got any left in the box even though I filled it just last week. QUESTION - anyone know the weight and dimensions of the gearbox for shipping Cheers Ian
| April 7th, 2013, 5:15 pm |
banjo
Joined: June 5th, 2009, 9:17 am Posts: 747 Location: Staffs & France
According to a previous post by Ken 23kg is the weight, I guess you will have to measure the box yourself
| April 7th, 2013, 5:54 pm |
Tripyrenees
yeah, just got my first quote through for shipping - €220 It would be cheaper to drive it there, stay over and drive back with it (all fixed  )
_________________ https://www.facebook.com/GNGLuscan
| April 7th, 2013, 6:10 pm |
banjo
Wow! at lea if you take it yourself you know it wont get damaged plus you can look over Vikings shoulder and learn too!
| April 7th, 2013, 6:22 pm |
Users browsing this forum: No registered users and 3 guests |
