View unanswered posts | View active topics It is currently May 1st, 2026, 2:55 pm
Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Engine compression
Post Re: Engine compression
2CViking wrote:
Logic is for people lacking imagination :mrgreen:
http://en.wikipedia.org/wiki/Logic
March 17th, 2011, 1:20 pm
More hot potatoes here :lol:
http://www.google.dk/search?source=ig&h ... sion+test+
March 17th, 2011, 1:50 pm
and cold ones
did you have a specific thread in mind with that link?
what point are you trying to make:-
    That you can get an accurate measure of the wear in an engine by testing it cold?
    There are other people in the world that dont understand how to do a compression test?
    There are as many opinions as there are people?
March 17th, 2011, 2:03 pm
Sean wrote:
and cold ones
No
My point is that many folks debate this.
No
No
Yes
March 17th, 2011, 2:16 pm
So, to summarise how this works;
A compression test can be carried out with the engine cold and the throttle closed.
All that's needed is a little imagination to determine how the results obtained correlate to those which would have been obtained if the test had been carried out under the correct conditions? :?
March 17th, 2011, 2:26 pm
As I already said, hard to swallow.
Yes cold test will indicate under what condition the engine have, when starting. Nothing more nothing less. Cold test has nothing to do with ''your correct test'' I ALSO do and agree with warm test and have never disputed that fact OK. All you need to consider is the benefit of a cold test in terms of starting problems, that's all. Forget warm test
March 17th, 2011, 2:33 pm
2CViking wrote:
Sean wrote:
and cold ones
No
No
No
Yes
Suggest you give them a quick read then -most consensus is that you do it hot WOT
then as an addition you can add some oil to see if the leakage is rings or other
March 17th, 2011, 2:35 pm
Sean wrote:
2CViking wrote:
Sean wrote:
and cold ones
No
No
No
Yes
I have. Most doesn't always means ''correct''
I shall rest my case, back to the garage to f.... up more cars :mrgreen:
March 17th, 2011, 2:39 pm
Do you ever concede a point? I have always followed the phrase "every day is a school day", clearly you like playing truant.
March 17th, 2011, 2:55 pm
A bit OT, but I just watched a man time his car up 180 degrees out. It didn't have much compression. I laughed.
March 17th, 2011, 9:27 pm
