View unanswered posts | View active topics It is currently April 29th, 2026, 3:21 pm
Reply to topic  [ 24 posts ]  Go to page Previous  1, 2, 3
 Argos air tool set - what fitting?!
Post Re: Argos air tool set - what fitting?!
I've got the Aldi compressor - the man at the industrial air tool supply shop called it a Mega Flow connector. He provided me with a converter to use my schutz gun for couple of quid.
February 15th, 2011, 10:59 pm
Thanks twomany and mesh, that's all good info.
I'm reluctant to change all my existing 'ends' or buy adaptors for each one - I know there are the 'correct' ones out there somewhere! Armed with your info, I shall continue on my quest...
February 16th, 2011, 12:19 am
Thanks to Knightley, Twomany and Mesh I believe I've tracked them down: They are called 'Hi Flow Uni' http://cgi.ebay.co.uk/Pack-3-Uni-Hi-Flo ... 4155ca7298
I could kiss you all.
***cough*** (lowers voice) er, in a manly way, of course...
February 17th, 2011, 12:01 pm
Ok, looking for a bit more assistance with a related issue, please... :D
I'm now confident I can get the same quick-release fittings as I have on my Argos kit, so I can also connect up my SIP spray gun to the whole caboodle (see above post). That's all fine and dandy - and thanks very much for the help.
However, I also need a similar quick-release fitting for a small cheapo 'touch-up' spray gun I got from China which I thought would be useful for doing stone-chips, etc. The female threaded inlet on this tool is smaller (by around 2mm diameter) than a 1/4" BSP female screw inlet, and it also has a noticeably finer thread pitch.
Any ideas wot size it could be?
Ta much (I'll, er, keep my kisses in check this time... :oops: )
February 24th, 2011, 9:44 pm
Users browsing this forum: No registered users and 76 guests
