ChrisW
 Re: Throttle problem
If it is just relying on the carb jets (after changing pump) then I would clean all of them as it sounds like second throttle one is blocked.
| February 4th, 2014, 6:07 pm |
Nelsthebass
I had all end of issues on the second choke on the Beige Beast...you have to clean, clean and clean again the jets, make sure there is no crap in the bowls and fit a filter close to the carb to stop the bits from a failing fuel line....
| February 5th, 2014, 12:05 am |
Riotpoll
Joined: November 29th, 2013, 8:44 pm Posts: 10 Location: Abbots Bromley, Staffordshire
Finally solved, swapped with the old carb I had lying around now working fine.
 AKA: Will
| April 26th, 2014, 5:28 pm |
Users browsing this forum: No registered users and 235 guests |
