A Panel removal for cooling...
 Re: A Panel removal for cooling...
Sean's post? ^^^^^^ " ...the scoops then act to draw air out the engine bay. " richardmorris wrote: No ones mentioned the Venturi effect yet!
| July 2nd, 2013, 11:31 am |
Smiffy
Joined: October 23rd, 2009, 10:41 pm Posts: 2356 Location: Worcestershire
ken wrote: Sean's post? ^^^^^^ " ...the scoops then act to draw air out the engine bay. " richardmorris wrote: No ones mentioned the Venturi effect yet! Didn't Venturi Effect support A Flock of Seagulls on their 1984 tour?
| July 2nd, 2013, 12:43 pm |
toomany2cvs
Worth checking that the sound-deadener stuck to the inside of the bonnet isn't blocking airflow out of the venty-venturi-thingy-dents that are already in the A-panel. Usually, it is...
| July 2nd, 2013, 1:36 pm |
dave 411
Joined: August 19th, 2010, 10:44 pm Posts: 1815 Location: Cardiff
Smiffy wrote: ken wrote: Sean's post? ^^^^^^ " ...the scoops then act to draw air out the engine bay. " richardmorris wrote: No ones mentioned the Venturi effect yet! Didn't Venturi Effect support A Flock of Seagulls on their 1984 tour?
_________________ [img]http://i1207.photobucket.com/albums/bb480/alastairsmith999/dave411-5.png[/im g]Horizontally Opposed
| July 2nd, 2013, 2:35 pm |
richardmorris
Joined: July 9th, 2009, 10:27 am Posts: 493 Location: Bagshot Park
ken wrote: Sean's post? ^^^^^^ " ...the scoops then act to draw air out the engine bay. " richardmorris wrote: No ones mentioned the Venturi effect yet! yes, but not by name
| July 2nd, 2013, 4:32 pm |
Bart
Joined: February 12th, 2009, 6:17 pm Posts: 316 Location: North
banjo wrote: DSCF3535 by 2steamhorses(Bob), on Flickr I shot this at Salbris a neat way of getting more heat out of the engine bay,the boot pretty cool to!! A simulare setup made a 10°C difference on my oil temperature on the motorway in Serbia cruising 100/110 km/h with about 30°C ambiant temperature. I think it works, cause I would think there is a depression behind the rear edge of the triangular panel (if that makes sense), sucking of air flow from under the bonnet. Otherwise the air is pretty much stuck between innerwings, panels, bulkhead and bonnet.
| July 2nd, 2013, 9:49 pm |
dave 411
Makes sense.
| July 2nd, 2013, 9:54 pm |
toomany2cvs wrote: Worth checking that the sound-deadener stuck to the inside of the bonnet isn't blocking airflow out of the venty-venturi-thingy-dents that are already in the A-panel. Usually, it is... Sean wrote: and loose any under bonnet fluff that hangs down.
| July 2nd, 2013, 9:55 pm |
4x4 SuperFinn
Joined: February 13th, 2009, 10:34 am Posts: 584 Location: Franken, D
Bart wrote: banjo wrote: DSCF3535 by 2steamhorses(Bob), on Flickr I shot this at Salbris a neat way of getting more heat out of the engine bay,the boot pretty cool to!! A simulare setup made a 10°C difference on my oil temperature on the motorway in Serbia cruising 100/110 km/h with about 30°C ambiant temperature. I think it works, cause I would think there is a depression behind the rear edge of the triangular panel (if that makes sense), sucking of air flow from under the bonnet. Otherwise the air is pretty much stuck between innerwings, panels, bulkhead and bonnet. I guess that it will be easy to spot who's been reading this post in Spain then!! Cheers for this tested info Bart.
| July 2nd, 2013, 10:06 pm |
Russell
Just for balance, I don't care either way.
| July 2nd, 2013, 10:23 pm |
Users browsing this forum: No registered users and 227 guests |
