View unanswered posts | View active topics It is currently May 1st, 2026, 4:29 pm
 2CV rear axle stub nuts
Post Re: 2CV rear axle stub nuts
last couple i did the threads on the stub chewed, perhaps relieving the staking leaves a "cutting edge" that messes the thread?
any problems with stub thread you non relievers?
April 16th, 2011, 1:58 pm
I never open the locked nut. Using a chisel or any other tool can make more damage to the thread. OK I have the luxury of this die to clean the thread if needed.
April 16th, 2011, 2:54 pm
ill stop relieving the staking, might need a bigger stick
April 16th, 2011, 4:27 pm
The "smoke wrench" (cutting torch) did the job! must be the skilled operator ha ha . Those nuts were TIGHT and the staking bashed into the axle slot. I don`t think there was any other way to get them off. Both nuts destroyed but everything else OK. Thanks for all of your posts!! paul
April 16th, 2011, 6:19 pm
:shock:
April 16th, 2011, 9:21 pm
I've not had any issues with the threads, it's never needed anything more than an occasional quick tickle with a thread file to get the nut started.
http://cgi.ebay.co.uk/Sykes-Pickavant-0 ... 35b14c8ce4
April 16th, 2011, 9:42 pm
twofifty,
same again, with the need for a thread file being a very rare occurrence, once a decade perhaps... :lol:
@ Sean,
consider how easily the similar, but smaller scale, staked nuts in the rear of a gearbox can be undone.
That's if they haven't undone all by themselves before the gearbox is opened. :roll:
Any small amount of deformation caused by the staking being pushed back out is cleared as the nut is unwound, I reckon.
April 16th, 2011, 10:58 pm
What a Great Forum! Please save me some time----What is the CORRECT TPI or thread flie (metric) to dress-up the axle treads? Us Americans always have a hassel to convert--I`m not sure something "close" works---I have nothing metric to do this but will find it to do this job. Thanks for the input---Paul
April 17th, 2011, 12:06 am
The files have eight flats, so eight different sets of teeth. I can't for the life of me remember which is applicable to the stub axle. One file covers most eventualities.
It is a useful tool to have, they're great for dressing the end of a bolt if you've cut one down to length. Both a metric and imperial file lurk in the top drawer of my tool box.
April 17th, 2011, 12:13 am
I just use this, to get the rear drums off. Have always worked for me, but maybe I haven't met the really stubborn ones yet:
I've had a look in the workshop manual, and it seems as these should only be tightened with 35-40 Nm,greased threads.
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
April 17th, 2011, 1:30 am
