View unanswered posts | View active topics It is currently April 29th, 2026, 1:54 pm
Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 gritting: tips and tricks and ideas please
Post Re: gritting: tips and tricks and ideas please
Jameswallace wrote:
well i mean when i pull into the drive after work when i get home (usually late) i spend 5 minutes cleaning it (well have done before) then 5 min drying then go inside and thaw out
So wax a panel a day.
November 30th, 2010, 11:57 pm
could do,
any suggestions product wise??
your right adrian i should pull my finger out and do a panel a day
still got to hose car down first though ;)
December 1st, 2010, 12:04 am
A quick "hose-down" (always assuming it doesn't just freeze and turn your drive into sheet ice) won't get the grot out of the places it'll do damage, anyway.
December 1st, 2010, 12:09 am
true,
where does it "get up and do the damage most" then?
i tend to get on the floor and spray the boot floor not just under the wings, i tend to do everything underneath (well the hole car!!) except the inside
December 1st, 2010, 12:11 am
Jameswallace wrote:
could do,
Do you really want a sea of ice down the drive and pavement from hosing down a car in sub zero temperatures? Not to mention frozen door locks and torn rubber seals. Just wash it thoroughly when the temperature rises for a few days, it won't be long.
December 1st, 2010, 12:12 am
The point of car wax is to seal the paintwork and prevent nasties getting through to damage it in the first place.
Toomany's idea of a panel per day is pretty nifty! Give yourself that target and it'll soon be done!
I don't see any point in removing the WAXOIL next year - all you need to do is hose it down to remove the dirt on it (which should come off pretty easily), let it dry, and apply a further coat(s).
I've heard that Auto Glym Super Resin Polish (I think it's called) is pretty good. Auto Glym also do a Top Coat Sealant as I've said before - this adds a further layer of gloss AND protection.
Has anyone tried the new type of PTFE-based polishes? Snake oil, or good stuff?!
December 1st, 2010, 12:13 am
old nail posted a link somewhere (think in the bamboo thread) of the wax he used, about 8 quid a thing on ebay, he said it was good
thats all i can tell you
i couldnt care if its glossy, just as long as it stops it getting through ;)
December 1st, 2010, 12:34 am
Then just spray the whole car with rustproof wax and leave it alone until spring.
December 1st, 2010, 12:35 am
i need to get a compresser,
i got one of those parrafin guns and tried it with a friends compresser, seemed effective sort of
so is the stuff DA is suggesitng appropriate to be sprayed? or do i just go for some cheaky clear wax oil and remove in spring?
December 1st, 2010, 12:36 am
Just take it to the pressure jetter once a week. Job done.
December 1st, 2010, 12:44 am
