View unanswered posts | View active topics It is currently April 29th, 2026, 1:54 pm
Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Loss of lhm
Post Re: Loss of lhm
rebel2cv wrote:
The master cylinder is brand new as i went through all the breaks this time last year.
I presume the level was topped up at that time, then? I can't see 'wear' causing such a drop in level since that time, so I suspect you have a leak somewhere.
Unless you are very, very, very heavy on the pedal?!
November 19th, 2010, 2:25 am
Jameswallace wrote:
slightly off topic in a sense, but where could i get some LHM break fluid from? i dont have any, and i feel i should have some just incase!!! ive never bothered checking the level since may woops!!
Citroen dealers ,about 8 quid a litre, GSF stores stock it (german-swedish-french, a good car parts chain), about 5 quid a litre, green bottle with citroen logo. There are also one or two other makes that do LHM.
November 19th, 2010, 11:37 am
Ah!
as V said check bulkhead inside the cabin( but then a new master shouldnt be leaking)
Wheel cylinders any sign of dampness at the backplate?
November 19th, 2010, 11:54 am
Just had a ciggi break and looked all round, everything dry except where the bottle pushes into the master cylinder.
November 19th, 2010, 12:54 pm
Sean wrote:
Ah!
Ya I forgot that the MC is new. Maybe the bottle is cracked or leaking around the seals. Did it leak before fitting the new MC
November 19th, 2010, 1:14 pm
could be its not seated right
push it firmly down then try to pull it up if it moves then the lip on the bottle hasnt got/bit in to its groove in the rubber they can need a fair old push and sometimes they drag the seal down rather than pushing through it
mine leaks badly if i do the cable tie trick so might be worth snipping that and having a push and a wiggle if youve tried that particular tip
sean
November 19th, 2010, 1:31 pm
citroen dealers, why would i want to go to one of them with a 2cv!!!
i geuss its brake fluid
im going to go into the motor factors when i get payed (which is only just around the corner from the citroen dealer anyway!)
November 19th, 2010, 1:43 pm
Because they sell LHM!! :!: :| ,LHM=liquid hydraulique minerale ,it's the stuff in big citroen hydraulic suspension system,same stuff is used in your late 2cv brakes!
I have bought it both from a citroen dealer and GSF, GSF was cheaper.
You could have been nearer a citroen dealer than anything else for all i know, s'why i suggested it..sorry for helping out :roll:
ps just in case you dont know LHM is thin mineral oil and not ordinary dot 4 or 5 brake fluid and if you put that in it will knacker your seals.
November 19th, 2010, 2:44 pm
It's ok I know not to put in normal break fluid, I'll give the tub a wiggle when I finish and top it up, then it's just a case of mopping up the leak and see what happens.
November 19th, 2010, 3:56 pm
nono i accept your help and am going to go to a citroen dealer, just was saying dont take it the wrong way!!
November 19th, 2010, 4:34 pm
