View unanswered posts | View active topics It is currently April 29th, 2026, 12:43 pm
Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
 Periodic dramatic loss in power
Post Re: Periodic dramatic loss in power
No prob .....bring it down Wednesday if you want.
2CV6 Special [Red]
C4 VTR+ Coupe [Black]
November 6th, 2010, 1:09 am
check floating device in the carb, to much or less fuel.
when you are checking this clean the whole carburetor
Awesome, PM me your address before Wednesday and I'll pop down.
November 6th, 2010, 1:10 am
PM sent
2CV6 Special [Red]
November 6th, 2010, 1:15 am
Pete, if you want to do a compression test (always interesting - although I doubt a worn engine is your problem here since it's intermittent) then (a) remove both spark plugs, (b) pull off one of the LT feeds to the ignition coil (not essential, but no point having sparks/shocks all over the place...), (c) screw the tester into one of the plug 'oles, (d) floor the throttle and crank the engine until the needle doesn't go up any higher - around 5 seconds ought to do it.
Take reading, repeat with other cylinder.
November 6th, 2010, 1:25 am
just a bit irrelevant,
ive been working more than usual recently with my friends on outboards,
weve had a load of the same outboards have similar problems (SIMILAR) and it was the float level, they where only 3.3hp outboards, and when you revved it died
anyway if its any help there you go!
November 6th, 2010, 10:42 am
Good tip should you want to take your 2CV out to sea ;)
November 6th, 2010, 11:04 am
Not quite right. You need two readings from each cylinder. One dry and one after you have squirted some oil into the cylinders. That's the way to determine if its valves or rings that are worn.
If the reading is good both times then all is OK.
If poor dry but good wet, then rings are the problem.
If poor dry and poor wet, then its valves.
November 6th, 2010, 11:08 am
November 6th, 2010, 6:51 pm
Cheers, 602 :)
November 6th, 2010, 8:31 pm
