subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2254 Location: Near Monmouth
 Rust Rot Excessive
Got myself a refurb body shell as the current item is very tired. Now to cut a big hole in the lower bulkhead for the prop shaft  Old Body Shell.... Low bulkhead and boot and the following. Attachment:
| May 26th, 2021, 2:01 pm |
subarupete
 Re: Rust Rot Excessive
Markout the GOOD metal to be removed...  Attachment:
| May 29th, 2021, 2:25 pm |
subarupete
Added some good Zintec to the hole with some average welds Attachment:
| May 30th, 2021, 12:03 pm |
rob massey55
Joined: December 21st, 2014, 7:33 pm Posts: 900 Location: Rhayader Mid Wales
all good stuff Pete, Ive been excavating some of the rusty stuff as well.
| May 31st, 2021, 6:26 pm |
subarupete
Yet another large hole, this time in the boot. Attachment:
| June 4th, 2021, 10:11 am |
AZL57
The holes have an advantage, they won't rust...
| June 4th, 2021, 4:25 pm |
subarupete
 also less kg that is until it, gets filled in with more metal than was removed
| June 4th, 2021, 4:43 pm |
rob massey55
I can see that you've been paying attention  . AZL57 wrote: The holes have an advantage, they won't rust...
| June 6th, 2021, 10:06 pm |
Roger V
You have to let the rain water out some how!
| June 7th, 2021, 6:10 pm |
subarupete
Covered with Primer and Seam Sealer looks reasonable  Added a kg or Two as the metal is 1.5mm where as the original is 1.2mm or less. Attachment:
| June 9th, 2021, 4:48 pm |
Users browsing this forum: No registered users and 320 guests |
