rob massey55
Joined: December 21st, 2014, 7:33 pm Posts: 899 Location: Rhayader Mid Wales
 Re: Yellow Dyane
These Covid Christmases we're all having aren't the best are they? I find that messing about with old cars is a pleasant distraction  . P1030555 by Robndaisy, on Flickr The scuttle panel's life has been hard, P1030557 by Robndaisy, on Flickr shouldn't there be a drain there? P1030560 by Robndaisy, on Flickr The other side, still intact and good for a pattern. I'm going to make a press tool that'll make (at least) two patch panels. Those rubber drain things are flamin' mad, but then...  . P1030562 by Robndaisy, on Flickr The bottom die is done, just need to sort out the plate for the top one. P1030563 by Robndaisy, on Flickr After all that good food etc. I needed the exercise. P1030564 by Robndaisy, on Flickr The first test, not too bad, I'm making the pressing just circular because it's too complicated to fabricate otherwise, with what I've got here  .
| December 28th, 2021, 8:27 pm |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1661 Location: Exeter, Devon
 Re: Yellow Dyane
Very inspiring  I need to find a lock up garage near me
| December 28th, 2021, 8:56 pm |
AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 2278 Location: South-Limburg
 Re: Yellow Dyane
Nice job Rob. We made a mould in hardwood for the sahara bonnet's spare wheel carrier. It went rather well
| December 31st, 2021, 12:14 am |
rob massey55
 Re: Yellow Dyane
P1030566 by Robndaisy, on Flickr P1030567 by Robndaisy, on Flickr P1030570 by Robndaisy, on Flickr P1030571 by Robndaisy, on Flickr P1030569 by Robndaisy, on Flickr P1030568 by Robndaisy, on Flickr P1030572 by Robndaisy, on Flickr P1030577 by Robndaisy, on Flickr P1030576 by Robndaisy, on Flickr P1030575 by Robndaisy, on Flickr That was a lot of work, good job it's not a restoration!
| January 16th, 2022, 9:07 pm |
AZL57
 Re: Yellow Dyane
Looks very well done. We used that airbox to smuggle bottles of wine when coming back from France..
| January 17th, 2022, 5:58 pm |
rob massey55
 Re: Yellow Dyane
Cheers! It was a flamin' pain to locate correctly (to make sure that the rubber seal fitted properly). I had to shut the bonnet and crawl inside to pin it and then I could open the bonnet and finally weld. nearly done with the bodyshell repairs but there's still work on the door bottoms, rear wing and front inner wing. I'll probably leave them and concentrate on putting the windscreen back in and then the wiring and dashboard. Still hoping to get it running and finish it this year  . Oh yeah, just remembered I've got to rebuild the flaming engine  .
| January 18th, 2022, 12:09 am |
Ianredspecial
Joined: June 22nd, 2014, 8:09 pm Posts: 1310 Location: Reading, Berks UK
 Re: Yellow Dyane
Does look good!
| January 18th, 2022, 12:47 am |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1196 Location: Magyarország
 Re: Yellow Dyane
COOL! As they say nowadays .
I wished I was that far with my 2cv AZ.
| January 18th, 2022, 8:49 am |
rob massey55
 Re: Yellow Dyane
thanks lads
| January 18th, 2022, 10:31 am |
rob massey55
 Re: Yellow Dyane
P1030578 by Robndaisy, on Flickr colourful... P1030579 by Robndaisy, on Flickr JCB yellow hasn't covered very well, yet. P1030580 by Robndaisy, on Flickr Hammerite smooth yellow is closer. P1030581 by Robndaisy, on Flickr Waiting for paint to dry, Pete decided to de-rust the battery tray bracket. No sun here  .
| January 24th, 2022, 11:27 pm |
Users browsing this forum: No registered users and 499 guests |
