View unanswered posts | View active topics It is currently August 14th, 2025, 4:23 pm
Reply to topic  [ 358 posts ]  Go to page Previous  1 ... 18, 19, 20, 21, 22, 23, 24 ... 36  Next
 Yellow Dyane
Post Re: Yellow Dyane
These Covid Christmases we're all having aren't the best are they? I find that messing about with old cars is a pleasant distraction ;) .
ImageP1030555 by Robndaisy, on Flickr
The scuttle panel's life has been hard,
ImageP1030557 by Robndaisy, on Flickr
shouldn't there be a drain there?
ImageP1030560 by Robndaisy, on Flickr
The other side, still intact and good for a pattern. I'm going to make a press tool that'll make (at least) two patch panels.
Those rubber drain things are flamin' mad, but then... :D .
ImageP1030562 by Robndaisy, on Flickr
The bottom die is done, just need to sort out the plate for the top one.
ImageP1030563 by Robndaisy, on Flickr
After all that good food etc. I needed the exercise.
ImageP1030564 by Robndaisy, on Flickr
The first test, not too bad, I'm making the pressing just circular because it's too complicated to fabricate otherwise, with what I've got here :) .
December 28th, 2021, 8:27 pm
Very inspiring :) I need to find a lock up garage near me :)
December 28th, 2021, 8:56 pm
Nice job Rob. We made a mould in hardwood for the sahara bonnet's spare wheel carrier. It went rather well
December 31st, 2021, 12:14 am
ImageP1030566 by Robndaisy, on Flickr
ImageP1030567 by Robndaisy, on Flickr
ImageP1030570 by Robndaisy, on Flickr
ImageP1030571 by Robndaisy, on Flickr
ImageP1030569 by Robndaisy, on Flickr
ImageP1030568 by Robndaisy, on Flickr
ImageP1030572 by Robndaisy, on Flickr
ImageP1030577 by Robndaisy, on Flickr
ImageP1030576 by Robndaisy, on Flickr
ImageP1030575 by Robndaisy, on Flickr
That was a lot of work, good job it's not a restoration!
January 16th, 2022, 9:07 pm
Looks very well done. We used that airbox to smuggle bottles of wine when coming back from France..
January 17th, 2022, 5:58 pm
Cheers!
It was a flamin' pain to locate correctly (to make sure that the rubber seal fitted properly). I had to shut the bonnet and crawl inside to pin it and then I could open the bonnet and finally weld. nearly done with the bodyshell repairs but there's still work on the door bottoms, rear wing and front inner wing. I'll probably leave them and concentrate on putting the windscreen back in and then the wiring and dashboard. Still hoping to get it running and finish it this year :) .
Oh yeah, just remembered I've got to rebuild the flaming engine ;) .
January 18th, 2022, 12:09 am
Does look good!
January 18th, 2022, 12:47 am
COOL!
As they say nowadays .
I wished I was that far with my 2cv AZ.
January 18th, 2022, 8:49 am
thanks lads :)
January 18th, 2022, 10:31 am
ImageP1030578 by Robndaisy, on Flickr
colourful...
ImageP1030579 by Robndaisy, on Flickr
JCB yellow hasn't covered very well, yet.
ImageP1030580 by Robndaisy, on Flickr
Hammerite smooth yellow is closer.
ImageP1030581 by Robndaisy, on Flickr
Waiting for paint to dry, Pete decided to de-rust the battery tray bracket.
No sun here ;) .
January 24th, 2022, 11:27 pm
