View unanswered posts | View active topics It is currently August 14th, 2025, 10:49 am
Reply to topic  [ 337 posts ]  Go to page Previous  1 ... 17, 18, 19, 20, 21, 22, 23 ... 34  Next
 My new 2CV, running restoration. In theory..
Post Re: My new 2CV, running restoration. In theory..
Wow amazing stuff!!!
I do hope this gets serious rust proofing ;)
December 25th, 2011, 11:02 am
Really, really nice work !!
December 25th, 2011, 12:43 pm
Thanks guys, yes it will be getting pumped full of waxoyl, and thoroughly painted everywhere.
December 29th, 2011, 6:54 pm
lidl chassis tape
http://www.lidl.co.uk/cps/rde/xchg/lidl_uk/hs.xsl/index_27618.htm
January 9th, 2012, 8:56 pm
Been a while.. spent this weekend messing about in the garage. Got a wing sorted, genuine new ones are too expensive and non gen ones don't fit, so decided to fix the old ones, starting with the better of the two.
This area was a bit crusty
Cut out
Made new one
And welded in
This bit was also a bit rough
Cut out and welded
Due to most 2CV wings seemingly doing this at the top of the arch;
...and generally being quite weak, I got some 4mm steel bar
And welded it round the inside lip
The difference in strength is amazing, so much more solid, feel like I could almost sit on it.
Repaired creased area
Blanked the side indicators, will relocate these somewhere else later.
A 5p did the job nicely
Thought I'd have a play with the front indicators, and get rid of the horrible big plastic ones.
Hole filled in
Cut out again..
Bent a bit..
More metal added..
And add some old Lucas 488 sidelights, fitted with amber bulbs.. Looks a bit more retro..
I also fitted new A panels, but lost the pics. Will post if I find them
Can't wait to do the next wing.. ¬_¬
February 6th, 2012, 2:36 am
as always a shonky series of bodges - poor car you sholld be giving it a name, having some sort of post 70s acid come down charleston colour way and some stick on trinkets
>sigh<
seriously, the wire edge wing is something my mate Norry used to do on the racer makes the wings soooo much stronger and certainly stood up to jostling.
whats the indicator looks good
February 6th, 2012, 9:20 am
You've hit the nail on the head there, just the look I'm after!!
The lights are sidelights or reversing lights, 50's and 60's Lucas L488. Like early mini indicators but with a flat lens and inset bulb. I might fit amber lenses, not sure yet.
February 6th, 2012, 2:59 pm
Looking grand, as expected.
Have you put drain hole in the recessed parts?
The characters I once worked with built a 2CV-based buggy with frenched rear lights and no drain holes, which made some very successful rust traps...
February 6th, 2012, 3:57 pm
Good point Ken, I hadn't thought of that.
February 6th, 2012, 5:01 pm
Any updates with this?
May 12th, 2012, 10:58 pm
