View unanswered posts | View active topics It is currently February 4th, 2026, 1:51 am
Reply to topic  [ 284 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 29  Next
 LGY 275P Rises Again!
Post Re: LGY 275P Rises Again!
Ok I've got an easy one for someone!?!?
Turn the key to start engine, engine starts fine turn key back again and engine keeps running...!!!! only stop when wire is taken off coil!!
I suppose this is the fact that I have run a live from the Postive on Battery to the coil?? do I instead need to run a wire from ignition key end to the coil??
or is it something else??
Or is it a problem with the ignition Barrel??
Dyane 12 1976 (ish)
July 3rd, 2011, 11:50 pm
If you've hot wired the coil it will keep running when you switch the ignition off. It is also possible to blow the diodes in the alternator if you switch the ignition off but the engine keeps running.......
July 3rd, 2011, 11:53 pm
ok so what is the best solution to yet another of my problems??
Dyane 12 1976 (ish)
July 4th, 2011, 12:26 am
Your ignition switch, if it is the original one, will have provision for a live feed to the coil. The easiest solution is to use it...
BTW, if you leave the coil powered up without a running engine for a prolonged period of time it doesn't exactly improve them.
July 4th, 2011, 12:47 am
No Probs there as haven't left the battery connected for well over a year now, I always disconnect it after every time !!!
Wouldn't you think there was already that wire in place....from the ignition,
I do still have 2 rogue wires that seems to plug into a little black connector on top of the alternator ( I wander if it is one of those) as without seeing a similiar car?engine I wouldn't know if there is meant to be 3 wires plugged into ya alternator!?!?
As I know on the Dyane there is only one wire!!
Dyane 12 1976 (ish)
July 4th, 2011, 7:52 pm
Have put a tester on those 2 wires...
1 is live when battery is connector, which seems a bit strange!!!
The other becames live when ignition is switched on...could this be the one that goes to the live on the Coil!!
Anyone have any ideas what the little black connector containing 2 male blade connectors on top of the alternator is??!!?? :?: :?:
Dyane 12 1976 (ish)
July 5th, 2011, 4:51 pm
Unplugged those wires connected to the alternator and the engine wouldn't start!!
So plugged them back in connected a wire from ignition to coil and bargain...result....
Only problem now is have a nice, great sounding misfire...
bet the timing has jumped out now!!!!!!! :x :x
Dyane 12 1976 (ish)
July 6th, 2011, 2:18 pm
Well some progress 2nite, Brought a motorbike accelerator cable kit, managed to use certain bits I had, mated them with the new cable and result have a proper working accelerator cable,
Now to find out where the very loud exhaust blow is coming from even though I have very recently gone round the whole system and freshly sealed up all the joints!!!!!! :?: :( :?:
B*O*L*L*O*C*K*S
Dyane 12 1976 (ish)
July 10th, 2011, 12:31 am
Almost 3 months and haven't even touched the beast!!!
Must get out there soon (garage) before the bad weather kicks in!!
Probably only half a day away from the MOT..I Must get motivated!
Dyane 12 1976 (ish)
October 1st, 2011, 10:22 pm
Spend half a day tomorrow and get an mot Monday!!
October 1st, 2011, 11:12 pm
Users browsing this forum: No registered users and 637 guests
