Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1661 Location: Exeter, Devon
 Re: My Beduino
I can bring you up to speed on the shopping list.
Speeduino (this has a MAP sensor built in) Arduino TPS 36-1 trigger wheel. Hall effect (HE) sensor
And progress
Phase one is ignition
Trigger wheel attached to back of fan pulley.
Manifold drilled for MAP connection
Bracket made for TPS
HE sensor bracket made up but not fitted as have to remove luminition to do this.
To be continued ....
| November 11th, 2017, 11:59 pm |
lpgo
 Re: My Beduino
What triggereheel are you going to use?? 36-1...
I know a guy who uses bycicle chain-tootwheels in an ami 8.. There are are chaintoothwheels with 36 tooth. Taking 1 tooth out put it at the back of the fan and you're done..
However I would recommend drilling the flywheel.. Much larger diameter so it is easier to pick up the signal...
| November 12th, 2017, 9:29 am |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2251 Location: Near Monmouth
 Re: My Beduino
Photos please.
| November 12th, 2017, 10:45 am |
Roger V
 Re: My Beduino
photos then
| November 12th, 2017, 5:33 pm |
Roger V
 Re: My Beduino
Geo I've always liked the idea that you drilled your flywheel. Have you any images so I can see the approach you took?
| November 13th, 2017, 7:42 am |
subarupete
 Re: My Beduino
VGS solution Attachment:
http://www.vgs2cv.be/index.php/en/home- ... ish/tuning
| November 13th, 2017, 12:04 pm |
lpgo
 Re: My Beduino
Roger V wrote: Geo I've always liked the idea that you drilled your flywheel. Have you any images so I can see the approach you took? [YouTube]https://www.youtube.com/watch?v=bOdvMAT6-6o&sns=em [/YouTube] http://www.youtube.com/watch?v=bOdvMAT6-6o&sns=em I measured the circumference, made a cad- drawing with 36 markes on equal distance. Glueded the paper to the flywheel. Drilled 35 holes free hand ✋ and it workes.. Everything with the engine in te car... I don,t like the vgs solution. If you have axial play at your crankshaft your signal is gone or you're sensor.. Putting it on the head of the flywheel it always workes..
| November 13th, 2017, 7:27 pm |
Roger V
 Re: My Beduino
The bike passed its MOT yesterday, and I've pretty much stopped grinning whilst riding it.  It needs the cooling fan fixing, but I've found as long as I go fast, the temperature stays down. ...... Geo, I'm so temped to go down the fly wheel route.  however, I don't know that I trust myself to drill it in situ, or even at all. Anyone know the correct/preferred method of cutting teeth into the flywheel?
| November 16th, 2017, 1:23 am |
subarupete
 Re: My Beduino
Option 3 Laser cut and shrink fit? https://rennlist.com/forums/928-forum/4 ... wheel.htmlOption 4 Milling machine with Index set up.
| November 16th, 2017, 10:16 am |
lpgo
 Re: My Beduino
Anyone know the correct/preferred method of cutting teeth into the flywheel?[/quote] Heres how the Dutch profesional megasquirt Guru does it.. http://www.bs-autotune.nl/shop/product_info.php/cPath/43/products_id/257Or take a look at his YouTube video of this.. http://www.youtube.com/watch?v=I_5ZYsABVMo
| November 16th, 2017, 1:20 pm |
