View unanswered posts | View active topics It is currently August 14th, 2025, 1:16 pm
 Time to put a 2cv to sleep for a bit !
Captain Slow
Post Time to put a 2cv to sleep for a bit !
As some of u know im of overlanding it to Australia in april :D :D and then stopping in Oz for a year or two
so slowboe is going into storage in a dry garage
what i want to know is , do i just drive it in and shut the door or is there a few things to do on it ???
it may cum out to play for the french world meeting ;)
cheers Oboe
March 4th, 2010, 6:49 pm
Post Re: Time to put a 2cv to sleep for a bit !
Drive it down to Louis' workshop, so when you come back and collect it for Salbris next year it will have been transformed into a beautiful 4x4! ;)
March 4th, 2010, 7:04 pm
I would remove the battery, run the carb dry ,change the oil (used motor oil contains seal damaging acids or something) ,and maybe jack it up and support it up on wood blocks so the weight is off the tyres if its going to be static for a few years .
March 4th, 2010, 7:06 pm
Old Bloke
and don't apply the handbrake
Now known as 602
http://www.2CVTech.co.uk
March 4th, 2010, 7:21 pm
Just park her as per normal but get someone to take her for a spind around the block every 3 month, no worries. We do this all the time with our cars down under + the many Europeans leaving car in Australia.
Happy trip 8-)
March 4th, 2010, 7:32 pm
Oboe,
much the same advice as Ben has given, plus the following, since you're planning to be away for such a long spell...
Remove the spark plugs, put a few shots of oil into each cylinder, turn the engine to top dead centre and screw the plugs in finger tight.
On your retour, remove the plugs, disable the ignition and spin the engine over (with that new battery you've had to buy) until the oil warning light goes out.
By that time, some of the fresh fuel that you've just put in the tank should have reached the carb, so you can install the plugs properly and fire her up. 8-)
March 4th, 2010, 9:34 pm
Captain Slow
Cheers peeps :D :D
il let u know how the derig go's
would love to neil , but the bank said no :lol: :lol: :lol:
March 4th, 2010, 10:06 pm
Oboe,
What happens if you don't. My Viking Van is sleeping in Melb. for the last year. When I picked him up, he started straight away, no worries.
March 4th, 2010, 10:13 pm
Have you had it started regularly? I'd rather a bit of oil in the bores than risk it siezing, and to help it before the oil is circulating when restarted?
March 4th, 2010, 10:33 pm
Yes that's my whole point. Get someone to start and drive the beast around the block every 3 month and you don't need to do anything. I don't, never will.
March 4th, 2010, 10:48 pm
