View unanswered posts | View active topics It is currently July 18th, 2025, 3:09 pm
Reply to topic  [ 3993 posts ]  Go to page Previous  1 ... 264, 265, 266, 267, 268, 269, 270 ... 400  Next
citroenboat wrote:
Wiped Gerty all over lovingly with old engine oil to preserve the rusty finish - practiced for years on women using baby oil to perfect this technique...
Known a lot of rusty women then!! :D
John Jordan
January 11th, 2015, 8:25 pm
took the manifold off, to be able to work on the carb, and to take off the air ducts and heat exchangers, to see where the oil leak comes from...
Image 2VC 1980, Vert Embrun
January 11th, 2015, 11:17 pm
Feckin Result! Celeste passed with only a few advisories and a new front number plate - best scrap heap A series yet.......
January 13th, 2015, 1:13 am
Took the 123 off Gerty and put points back, she appeared to start on both cylinders and felt 'lively' (if you can say that about a 425 with terminal compression failiure); tomorrow I will find out if she starts from cold on both... :?
Mike
January 15th, 2015, 12:38 am
Hinge rivetted to the windscreen frame:
January 19th, 2015, 12:29 am
:roll: Are you French :lol: Do it again and properly :mrgreen:
January 19th, 2015, 9:17 am
Harley wrote:
3400x190x45
[URL=http://s350.photobucket.com/user/bimba101/media/Mobile%20Uploads/20150108_120155_zpsts1v7f79.jpg.html]
2400 and 2100 lengths.
Image[/URL]
8-)
Thanks Harley, these pictures have got me round to finely fit a hatchback set up, I've had lurking in the loft for yonks, like the rear light panel too, might pinch that idea for my hack :o
January 20th, 2015, 8:24 pm
It HAS been done properly.
When we took of the old frame, the only part not rusted was behind the hinge.
So I removed paint from the new frame, took of the hinge (there were allready rust behind the hinge), got it galvanized, and rivetted it on with sealant between hinge and frame..
NO welding!
Airplanes are rivetted as well!
Old fart!
January 21st, 2015, 11:08 pm
You obviously don't know the difference between aviation rivets and back yard shit rivets
Bastard
January 22nd, 2015, 12:13 am
Are they aluminium rivets?
January 22nd, 2015, 9:46 am
