wiltz
 rear box rubber mounts ?
Hi, I have a question, does anyone know what rubber mounting is used on the rear of the rear box in a Louis Barber 4x4 mine has gone a bit perished, I have ordered standard type engine front mounts for the front of the back box, but I don't know the origin of the rear one..
Thanks
| October 5th, 2017, 5:01 pm |
lpgo
 Re: rear box rubber mounts ?
wiltz wrote: Hi, I have a question, does anyone know what rubber mounting is used on the rear of the rear box in a Louis Barber 4x4 mine has gone a bit perished, I have ordered standard type engine front mounts for the front of the back box, but I don't know the origin of the rear one..
Thanks I know that mr. Barbour uses a lot of mountings from Landrover, so I guess it will be used here too.. Can you make a foto and post it here... P.s. Take a look at his site and sent him an email. http://www.barbour4x4.com
| October 5th, 2017, 5:23 pm |
wiltz
Thanks will do
| October 5th, 2017, 5:27 pm |
wiltz
Contact from web page not firing up at the moment, will try later, meanwhile going to look on some Land Rover sites for clues
| October 5th, 2017, 5:33 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2257 Location: Near Monmouth
Likely to be Peugeot mounts, on later designs ???
| October 5th, 2017, 5:44 pm |
wiltz
This car was built 2002, if thats any help.
| October 5th, 2017, 7:10 pm |
wiltz
Seen in circle
| October 5th, 2017, 8:26 pm |
subarupete
Pretty sure thats from a Peugeot, does it need replacing?.
On my version (2003) I have 2 mounts and they are fine, the front ones have been done a few times as they shear into two parts.
| October 6th, 2017, 9:22 am |
subarupete
From LB
Rear single mount is probably from an AX gearbox top mount
later versions use Saxo gearbox top mount
| October 10th, 2017, 9:33 pm |
wiltz
Thanks
| October 19th, 2017, 6:56 pm |
