Pony
 Re: Pony's Project - 4x4
I could do, it as flat pack but prefer not to as
Without the Jig Table it would probably warp and loads of chance to get the welding sequence wrong!
( about 3 test chassis out in the back yard rusting, waiting for the scrap)!!
However plans are a foot and already laser parts are cut, to build a 4x2 L W (Lighter weight version)
From this year onwards I am offering L W versions of several parts
Not yet on the Jig table so not sure on weight but probably in the 65 ish KG region
and hopefully Ali front sump guards From a local source!!
pony
| April 23rd, 2013, 9:05 pm |
Pony
Tank
Hmm looking to fit 2 about 10 litre each on each side of the rear chassis legs under the boot floor Ali,
so am working on the drawings this week and may have one in 2 weeks
however for the future
A stock tank would be best but still aint found what i am lookin for! Nothing available in the Citroen Peugeot Range
| April 23rd, 2013, 9:13 pm |
lpgo
Close the tunnel/tube in the chassis at the front and rear end, al least 30 liters only problem is going up/downhill when almost empty Now what is that tunnel/tube for anyway...... propshaft goes above the chassis I guess
| April 23rd, 2013, 10:16 pm |
1/ Closer to 15 litres? 2/ Torque tube? http://www.engadget.com/2011/04/14/trex ... -true-tor/lpgo wrote: Close the tunnel/tube in the chassis at the front and rear end, al least 30 liters only problem is going up/downhill when almost empty Now what is that tunnel/tube for anyway...... propshaft goes above the chassis I guess
| April 23rd, 2013, 10:47 pm |
lpgo
Well I don't think I know much about chassis I guess... I think I was the first who build a galvanised 2cv (4x4) chassis... and yes it was/is road legal too.... Had a whole discusion with Louis about distortion, weight gain and sagging back then. Soon afterwards Louis started to galvanise his chassis too...... The only thing I try to say that a 2cv has a ladder chassis, so the tube doesn't give much torque strenght overall, meaning there are lighter ways to give a 2cv chassis torque strenght then this tube....... Well we here it from the master.... I hope... Attachment:
| April 23rd, 2013, 11:35 pm |
Other ways have crossed my mind, that's for sure... IMG_0042 by slcchassis, on Flickr lpgo wrote: The only thing I try to say that a 2cv has a ladder chassis, so the tube doesn't give much torque strenght overall, meaning there are lighter ways to give a 2cv chassis torque strenght then this tube.......
| April 24th, 2013, 12:50 am |
lpgo
CRUEL
| April 24th, 2013, 7:26 am |
ken wrote: Other ways have crossed my mind, that's for sure... IMG_0042 by slcchassis, on Flickr thats almost re inventing the wheel  guess the hourglass shape of the original chassis was halfway between a cruciform and a central box beam. again Citroen did the most with the least amount of material - shame they were so corrosion prone.
| April 24th, 2013, 8:12 am |
lpgo
Sean wrote: again Citroen did the most with the least amount of material - shame they were so corrosion prone. Amen.
| April 24th, 2013, 12:15 pm |
Pony
Actually the tube down the centre of the chassis really does make it stiffer
I use round tubing as 100 mm of tube gives about 310 mm of un rolled plate this is about 25 % less than a box section
100 mm tubing with 2.00 mm wall thickness is Easy to find and fair price Does not distort during welding and and and And more importantly
Mounting possibility for
Seat belts Seats Propshaft bearing
(also i hope to seal in the drive train with rubber bellows to the gear box and diff
so mud free enviroment!
Think back to Haflinger they use a tube for the main chassis!
pony
| April 26th, 2013, 8:55 pm |
