View unanswered posts | View active topics It is currently May 1st, 2026, 9:44 am
Reply to topic  [ 11 posts ]  Go to page Previous  1, 2
 Dip-beam
Post Re: Dip-beam
Most likley scenario is that it is fitted but not working :D
Do you have a pair of relays fitted near the battery tray? and a spare rubber booted plug on the front loom with or without a small ally can like a bigger indicator can you got under the dash?
if so then thats all the cause of the hot switch
pull off the plugs on the relays one has 5 wires the other 4
on the 5 wire plug join socket 1 to socket 5 with a jumper( short wire with a lucar spade on eithet end. the numbers are on the base of the relays
June 29th, 2009, 11:48 pm
Users browsing this forum: No registered users and 74 guests
